Presto MyJo - K-Cup Brewer
Discussion in 'Pots, Pans, Grills, Other Cookware / Cleaning & Fo' started by Kampus, Aug 19, 2019.
  1. Kampus
    Kampus Active Member
    196
    177
    Jun 16, 2017
    Slate Belt, Pa
    I have been meaning to post a review for sometime but keep forgetting. So here goes.
    https://www.amazon.com/Presto-02835-Single-Coffee-Maker/dp/B00HIXSAXQ
    This thing has got to be the best $14 camping bucks I have ever spent. The DW is a coffeeholic. She drinks coffee like I do a some cold brews when camping....no good coffee, no camping kinda situation.
    In the past I had to run the generator multiple times a day just to brew her a pot of coffee.
    Now I just quickly boil some water on the stove and she is set.
    1. Heat some water
    2. Pop in a k-cup or filter and screw on the base
    3. Fill the top with hot water and pump it by hand right into the cup.
    The whole process is quicker than starting the genny and brewing a pot. Clean up is easy.
    I know there are those that don't care for the "environmental" effect of K-cups, but there are still options. It comes with a re-usable single serving filter cup, so no waste. There are also friendly brands of K-cups, Chock Full o'Nuts "cups" are little more than a filter.
    Sjm9911 and neighbormike like this.
  2. nineoaks2004
    7,745
    3,397
    Dukes, Fl
    Looks interesting, I have used a french press for years which works similar, I think and I love it. The DW says I do not drink coffee but chew it :) I finally got her to leave my coffee cup alone, Being in the Navy for so long we do not wash our cups but a light rinse works.
    Sjm9911, neighbormike and Kampus like this.
  3. Kampus
    196
    177
    Jun 16, 2017
    Slate Belt, Pa
    We have used a french press in the past. It worked pretty good, but she always found the coffee a little...thick.
  4. jmkay1
    5,271
    2,090
    I bought and used this on my last dry camping trip. Saved the day! I never had luck with a perculator and pour overs were always so weak that I had to pour over multiple times to get some decent coffee. The My Jo falls slightly short of regular drip coffee but stronger than a pour over. I now use it all the time for my coffee when dry camping.
  5. bheff
    bheff Well-Known Member
    1,476
    870
    Feb 24, 2011
    NW Arkansas
    You cant use "good coffee" and "k-cups" in the same paragraph.....[:D][LOL]
    nineoaks2004 likes this.
  6. JWeible
    JWeible Active Member
    120
    62
    May 11, 2015
    I LOVE my MyJo. I use the reusable filter so I don’t have the trash from the kcups.
  7. dbhost
    dbhost Well-Known Member
    814
    321
    Sep 19, 2018
    League City, Texas USA.
    Worth a look into for sure. Pour overs typically brew too weak, I add a paper filter to my permanent filter in my pour over...
  8. Sjm9911
    5,965
    3,419
    That does look cool. I might need one.
