Problem with Coachmen Glide-n-Lock bed system
Discussion in 'Miscellaneous Repairs & Maintenance' started by chola, Sep 29, 2015.
  1. chola
    chola New Member
    Sep 29, 2015
    I have a 2012 Coachmen Clipper 1285sst with the Glide-N-Lock bed system. I have recently started having issues with one of the bunks coming "unlocked" while deployed. When I pull the bunk out, I hear the locks engage on either side of the bed rails. However, occasionally when someone is laying in the bunk and shifts their weight, one side of the bunk unlocks, causing one rail to slide in about a foot, causing a momentary feeling of falling that frequently results in a loud scream. :)
    While the cable continues to support the bed, and no one actually does fall, it certainly is unsettling. Upon inspection, I see that the plastic cap (bunk stop) on the problem bed rail has a "gouge" in it. I assume that this is providing a ramp for the pin in the bunk spring plunger latch (the pin with the little ball on it) to ride up enough to disengage, and allow the bed rail to slide back in. Inspection of all of the rest of the bunk stops shows similar wear, but without as deep of a gouge, leading me to believe that they will all eventually have the same issue.
    Have any other Glide-n-lock owners had similar issues? I see that the bunk stops are available for purchase, but wonder if there is a better alternative. I see there are Bed Wedgies for Coleman owners, and am wondering if there is a similar alternative for Coachmen campers.
    Also, I am wondering if someone has indeed done this repair themselves, how they went about removing the rivet that holds the bunk stop in the rail. Any ideas?
    Thanks in advance!
  2. chola
    chola New Member
    Sep 29, 2015
    To anyone out there that might end up reading this post because of similar problems, I ended up ordering replacement bunk stops from Coachmen. You receive 4 of them, so I will have spares if I have problems with the rest of them. I ended up drilling the rivet out, starting with a small bit and working my way up until I was able to use pliers to pull the inside rivet end off. I replaced the cracked bunk stop with a new one, and instead of riveting the new bunk stop to the bed frame, I used a 3/16 x 1/2 inch binding post with screw. I got the binding post and screw at Home Depot. I believe this will be just fine, but will keep an eye on it.
    Anyway, no more problems once I replaced the bunk stop!
  3. SoBe
    SoBe New Member
    Aug 1, 2017
    My new 1285 is doing this, I'm going to have it fixed under warranty, but I'm curious if this has been an ongoing issue once you repaired it.
  4. chola
    chola New Member
    Sep 29, 2015
    I have not had to replace the bunk end again. However, the binding post gave way, so I am now just using an appropriate sized screw and nut to retain the bunk end. I still have 3 spares if I need them.
  5. BenL
    BenL New Member
    Apr 19, 2018
    Chola where did you get the bed stops from. I have been looking for a supplier and have not had any luck. Can you provide the parts source and contact info. Have been chasing this for three months.
  6. Dave Brick
    Dave Brick El Cheapo Family Camper
    224
    179
    Nov 29, 2010
    My cheapo and low skilled solution is a "C" shaped vice grip pliers knockoff from harbor freight. It holds the rail in the frame perfectly, and is small enough to be out of the way.
    I suspect that if the first plastic cap bunk stop failed, then subsequent replacements will fail as well. Good luck with your repair though, I hope it lasts forever!
    Dee L likes this.
  7. Msclipman
    Msclipman New Member
    Oct 21, 2019
    Ben, I found the bunk stops for my Clipper (Forest River) from Hannarv.com. They have a good selection of pop up parts. THIS IS IMPORTANT. While I was replacing the bunk stop, I noticed the latch pin on the good side was extending further down than the bad side. The reason it slipped and caused the damage to the stop was because the pin only extends down about 1/4 inch. After comparing I discovered the difference was the knob. Heres the fix to keep if from happening again: With the beds in a few inches and the pins up, hold the pin and take the knob off. You should see about 1/2 inch of threads. Apply a drop of thread lock to the top, then screw the knob on only about half way. Now the pin should go down further. You can see the difference in the pictures. Also, I used a 1/4 X 1 inch countersunk bolt with a nylon lock nut for the bunk stop. The nut can be on the inside without hitting anything.
  8. Guzzy
    Guzzy New Member
    May 4, 2020
    Omg! I've been searching for an answer to this issue for 9 months!! Am so glad I found this page!
  9. tjbaker72
    tjbaker72 New Member
    Jun 29, 2020
    I'm not able to find this part on hannarv.com. Can someone post a direct link? Thanks!
  10. Guzzy
    Guzzy New Member
    May 4, 2020
  11. tjbaker72
    Jun 29, 2020
    Guzzy, that is not the glide-n-lock part that Msclipman describes and posted pic of in post #7 of this thread. I need the housing, pin, spring and knob you can see in the pics attached to #7. I have that exact part in my 2013 Coachmen Clipper 128LS.
  12. tjbaker72
    Jun 29, 2020
    Actually, turns out all I need is the ball that screws into the pin as I found the pin and spring. I think I'll just try to find something at my local hardware store.
  13. Guzzy
    Guzzy New Member
    May 4, 2020
    Where were you able to find the pin and spring? I'd like to get a couple as spare backups.
  14. tjbaker72
    Jun 29, 2020
    The pin and spring were never lost; I found them in rattling around in one of the camper drawers. Someone in the family had the good sense to put them away for safe keeping but neglected to tell me about it!
  15. travel with tea
    travel with tea New Member
    Aug 31, 2020
    We've bent the housing for the pin and spring mentioned above. Has anyone found that or know what it is called so I can search for it?
  16. KHoss
    KHoss New Member
    Aug 19, 2021
    I just bought a brand new Clipper 125st and have the problem with the glidlock becoming disengaged with the slightest bit of movement on the bed. We haven't even used the camper yet! I have to take it back to the dealer so they can find a solution for it. The issue with my glidelock is only about 1/4 of an inch catches the rail to "lock" it in place. I have a camping trip planned tomorrow so I went to HF and bought some 1" C clamps to hold the rail in place until I can get it fixed/replaced. 20210819_101735.jpg 20210819_112209.jpg 20210819_122136.jpg
  17. travel with tea
    Aug 31, 2020
    I would be curious to hear if your c clamp works as that would be a workaround til I figure out how to bend the housing back into place . Please can you post an update?
  18. KHoss
    KHoss New Member
    Aug 19, 2021
    Will do, I'll be back Sunday
  19. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    Looks like a pair of Channel-locks would work.
  20. KHoss
    KHoss New Member
    Aug 19, 2021
    Channel locks would work great, but I don't want to mar or bend the aluminum because I have a warranty on the camper and this will be fixed by the dealer.
