Problems routing wiring kit 03 Dodge Caravan
Discussion in 'Tow Vehicles, Hitch & Towing' started by mickisdad, Jul 13, 2008.
  1. mickisdad
    mickisdad New Member
    25
    Apr 4, 2008
    I am having problems routing the wiring kit on my 03 Dodge Caravan. I have it all hooked up, but cannot figure out how to route it so that it comes out underneath the TV. On our two trips so far I have just had it hanging out through the rear door. Does anyone have any ideas on where I can look or what to do?
    Thanks
    Sean in MD
    Sean, Jenn and Micki
    from Maryland
  2. pixel
    pixel Campers: Nature's way of feeding mosquitoes. Unkn.
    447
    May 4, 2008
    Massachusetts
    I have a T&C 2002, same body basically.
    When I got my hitch installed at Uhaul, they said that they could not mount it on the bottom. (elec harness), so we just keep it loose in the back cargo area.
    I will have my DH look at options today and get back to you.
    There are these brackets that are sold at Uhaul that somehow mount to the hitch on the outside. They look like "ell shaped" brackets, with a circle whole in them where the elec. harness is to fit. I do not know much about them, but will get more information later. Try going to uhaul.com and see if they are there.
    Pixel
    99 Coachmen Hunter Pop-up
    02 Town & Country
    Pix (Me), DH, 3 DD's
  3. 01YZF6
    01YZF6 Dothan, AL
    2,336
    Apr 5, 2008
    Mt. Washington, NH
    ifit is anything like my Kia Sedona, you are very limited on options. we have the T-connector type. It basically hooks off the tail lights. we store it in the side compartment when not in use.
    I looked at mounting it underneath too, but the exhaust and spare tire would have been in the way.
    my original thought, which may help you, is if you lifted up the inside rear tire deck/storage lid, drill a hole, stick a rubber grommet in there, run wiring through grommet, zip tie/clip the plug to the frame of the hitch.
    again I looked at doing it this way and it was just easier to keep it stored inside.
    maybe you could do some browsing on the caravan forums for ideas? the sedona forums helped me in quite a few tips/mods departments
    Robin, Working hard so DW & 3 DS's can play harder.
    '87 Coleman Newport aka "The Nut Hut" <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">
    '03 Kia Sedona <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle">
  4. oak
    oak New Member
    331
    Aug 1, 2007
    There should be rubber grommets (drains)in the spare wheel well or elsewhere. Pop it off, hopefully it fit thru there, if not cut and splice.
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">'04 Coleman Yuma aka "Poppet"
    '08 Ridgeline Don<img src=../Images/icons/icon_smile_bike.gif border=0 align=middle alt="Bicycle">
    and Ann<img src=../Images/icons/icon_smile_chef.gif border=0 align=middle alt="Chef"> Mr. Martin -- the Dog
    Edited by - oak on July 13 2008 10:57:37
  5. pixel
    447
    May 4, 2008
    Massachusetts
    mickisdad
    I wanted to get back to you. My husband suggested that you go to a trailer hitch store or the dealer. Sorry, I wish I could have helped you.
    Pixel
    02 Town & Country
  6. jerkin
    jerkin New Member
    32
    Jul 23, 2007
    Like Oak said, pull out the spare tire and there is a hole with a cover below it that you can run through. That's where I took the one on our 05 caravan out.
  7. Storm Trooper
    3,544
    Feb 14, 2008
    If you're storing the vehicle end of the 7 way connector inside, it's going to last a whole lot longer than the rest of ours as it isn't subject to as much moisture and or salt/sand etc.
    It's not all that bad, had to do it on my previous TV. Just be careful not to pinch it in the door lock and you'll be fine..
    Lou
    43 days booked for 08.<img src=../Images/icons/icon_smile_camping.gif border=0 align=middle alt="Camping">23 nights camped in 08
    07 Fleetwood Avalon (Great White)
    03 Ford Expedition (Green Monstah) GO Red SOX!!!
  8. coleman83
    coleman83 New Member
    191
    May 24, 2008
    Mine is inside as well the hole over the spare tire is not even big enough to pass a 4-flat through.
    83 COLEMAN SUN VALLEY
    05 CHRYSLER T&C
    96 DODGE RAM 1500
    Edited by - coleman83 on July 21 2008 17:17:08
  9. oak
    oak New Member
    331
    Aug 1, 2007
    Cut and splice
  10. barb_dave
    barb_dave Active Member
    1,731
    Jul 22, 2007
    Wisconsin
    On our 97 voyager I ran it from under the side panel then under the rear sill plate. I had enough space between the bumper and the body to route it to the underside of the van. I wouldn't recommend removing the rubber grommet where the spare is or you'll be prone to water getting in. If you would go through the grommet make sure to reseal it with undercoat.
    http://community.webshots.com/user/Barb_Dave
    1998 Coleman Mesa 1997 Voyager
    Nights Camping 2008-9
