Problems with leaky door
brino
New Member
Jul 20, 2009
Vandalia, Illinois
I'm new to pop ups and was wondering if leaking doors is just part of it. When ever it rains the door leaks. With the split design and dropping fron the roof it is very sloppy once put in place...
whenever there is a shift in weight the door jams and does not want to open properly,. Am I doing something wrong? How do I stop or slow down the water?
campfixer
199
As far as the leaking, I am assuming that you have a gasket or something damaged or you are not setting up correctly. A photo from inside and out setup as you normally do would help us help you.
Your stuck door could be due to not being set up level with stabilizers properly adjusted, due to water damage to the wood floor or framework or a combination of both.
