Problems with lift system
Discussion in 'Lift Systems' started by Sould853, Sep 29, 2019.
  1. Sould853
    Sould853 New Member
    Sep 29, 2019
    I am a newbie and have a new to us 1997 Coleman Fleetwood Sun Valley. I have a hand crank system that “pops” when it is raised. It does not do that going down. I have adjusted or righted all the cables. The back end of the whiffletree would bounce when it was being raised so I think I have fixed that. The chain appears loose - I can push it together between the two sprockets easily. But if I remove a link to tighten it, I can’t get the chain back together. Just the one link removal seems to make it too short. Do I need to replace the bearing on the whiffletree? I have been doing various repairs on this camper since purchased and still haven’t used it yet. Any suggestions would be appreciated. I am in central Texas.
  2. Raycfe
    16,563
    2,312
    You maybe able to find a half link.
  3. nineoaks2004
    7,750
    3,404
    Dukes, Fl
    Welcome from lake Butler Fl. Congrats on the NTU PUP, good luck and happy camping
  4. Sould853
    Sould853 New Member
    Sep 29, 2019
    Thank you for the welcome. I appreciate it. Could not find a half link anywhere in town (small town) would have to order it. SO i put the chain back together, lubed it well with a dry lube so the brake pad would not get dirty or greasy. Went back and checked then tension on the cables, then greased the whiffletree as well. At this point, there is no popping, but the popping had stopped once before after I adjusted the tension on the cables and tightened the bolts holding the tail end of the whiffletree. Hopefully it will stay fixed this time. I don't like drilling out all those rivets to pull the back panel off, which is the only way to access the chain assembly!
