Propane Adapter?
Discussion in 'Propane - Got Gas' started by Rachel Richards, Feb 10, 2020.
  1. Rachel Richards
    Rachel Richards New Member
    Feb 10, 2020
    Ridgecrest, CA
    Hi! I am new pop up camper, but not new to camping. My question is about using a large propane tank for my cook stove and lanterns as opposed to the small green cans. What type of adapter and hoses do I need? Thank you for any info
  2. xxxapache
    2,991
    980
    Search " bulk propane tank adapter hose". They are usually between $10 and $20.
  3. Rachel Richards
    Feb 10, 2020
    Ridgecrest, CA
    On Amazon?
  4. nineoaks2004
    7,558
    3,274
    Dukes, Fl
    I bought mine at Lowes, works good and sure beats using those little cans of LP, I also have an adapter to re-fill the small cans. Best way to carry the 30# tanks is in a milk crate, they are more stable when carried that way. Good Luck and happy camping
    Econ likes this.
  5. xxxapache
    2,991
    980
    Lowes, Walmart, Home Depot and so on usually have them. You can find them in the camping section and the section where Blackstone griddles are sold.
    kcsa75 likes this.
  6. Rachel Richards
    Feb 10, 2020
    Ridgecrest, CA
    I guess I'm just not sure what they are called to look to buy.
  7. xxxapache
    2,991
    980
    I also I carry an adapter to fill one pounders from a larger tank.
    I use a plastic foot on 30 pound tank to keep them from tipping. Mr Heater is one brand
  8. Rachel Richards
    Feb 10, 2020
    Ridgecrest, CA
    What was the product called that you purchased? I'm not sure what it would be called to even look for.
  9. xxxapache
    2,991
    980
    Bulk tank adapter hose....Its a 3 or 4 ft long black hose with a brass fitting on one end and a larger plastic turn knob fitting on the other end.
  10. Sjm9911
    5,279
    2,881
  11. Rachel Richards
    Feb 10, 2020
    Ridgecrest, CA
    Ok! Thank you. I will try and find it.
  12. Rey-Pop-UP
    Rey-Pop-UP Member
    30
    32
    Jan 31, 2020
    Sacramento, California.
    PropaneGear.com sells plenty of propane adapters for RVs. Great Quality also.
  13. Rachel Richards
    Feb 10, 2020
    Ridgecrest, CA
    Thank you! I will check it out!
