Propane distribution post mounted to side of pup?
Discussion in 'Propane - Got Gas' started by lksdrinker, Sep 18, 2019.
  1. lksdrinker
    lksdrinker Active Member
    202
    50
    Oct 15, 2018
    Has anyone tried (or thought of trying) to mount a distribution post to the high pressure output on the side of a popup? I wouldn't mind being able to run propane lantern and use the propane I already carry as fuel (instead of the 'disposable' 1 lb tanks).
  2. Aladin Sane
    1,060
    99
    Jul 3, 2008
    Iowa
    I have been pulling one of my two tanks off the tongue and using such a device to power my coleman camp stove mounted on the side of my camper where the RVque would sit. I really need to add a tee in the line from one of the tanks and run a high pressure line to the point the low pressure quick connect now sits. That may be a winter project for me.
  3. dbhost
    dbhost Well-Known Member
    809
    315
    Sep 19, 2018
    League City, Texas USA.
    Assuming you have clearance over the main tanks, you can use a Y fitting
    And the tougher part, sourcing up a Century tri outlet distribution post.
    The advantage of the Century post is that is clamps to the safety ring, not the valve, this will allow you to keep the tank connected to the PUP.
    Just remember to REMOVE the Y splitter once you get done with the distribution post...
    Personally, I would prefer Coleman Fuel / Dual Fuel lanterns / stoves vs propane. You aren't dependent on the location of the propane tank and hoses...
  4. lksdrinker
    202
    50
    Oct 15, 2018
    I thought about adding a "Y" like that at the tanks, but would rather have my source coming from a more accessible spot when the bunks are out.
    Duel fuel stuff is nice (and I do own it) but since I have the propane tanks on the pup I was hoping not to also carry a can of gas!
    That century post is interesting....still hoping to use something like that mounted to someplace other than the top of the propane tank.
  5. dbhost
    809
    315
    Sep 19, 2018
    Hmmm. Yeah you do have a challenge there...
    If it's just a lantern, maybe run the hose to the lantern on a hanging stand, keeping the hose draped down pulling the lantern to the proper orientation.
  6. Aladin Sane
    1,060
    99
    Jul 3, 2008
    Iowa
    I ended up putting a tee at the tank. One of the branches of the tee had a fitting like a 1 lb cylinder. I attached a high pressure hose to that, ran it under the pup and up through the cabinet where the existing low pressure quick connect comes out the side of the pup. That end then screws onto the propane regulator on the high pressure stove I hang on the side of the pup.
  7. jdkmrc
    jdkmrc New Member
    Oct 3, 2018
    To run my Blackstone griddle I disconnect one of my tanks and run a 25' extension hose. I think I'll put one of those Y-fittings on my list to Santa.
  8. BillyMc
    BillyMc Well-Known Member
    1,218
    577
    Mar 25, 2018
    I don't know if there is any rules or regulations that apply to high pressure LP indoors. I have heard all my life that high pressure lines and hoses other than direct connected are a big no no indoors. Following what I've heard everything should be on the outside of the camper. That being said, I have been known to run a hose from a 20lb tank though the velcro inside to my Buddy heater.
    WingmanHG likes this.
  9. lksdrinker
    202
    50
    Oct 15, 2018
    I'm not sure why I'm so opposed to splitting the propane from the tank directly. Maybe its just because the lines are already plumbed in and there waiting to be used. Maybe I'll get a splitter and use it right at the outside stove connection (instead of at the tank) and use hoses from there.
    My plan is for outside of the pup.
  10. Adam H
    Adam H Active Member
    391
    135
    Aug 22, 2015
  11. lksdrinker
    202
    50
    Oct 15, 2018
    I'm already carrying 2x20 lb propane tanks on the popup. It'd be nice to not deal with the "disposable" propane bottles if I didnt have to. I'm currently refilling the little ones and find that some bottles for some reason start leaking once you try to refill. So besides the hassle of doing the work, I'm sometimes wasting propane by even trying to refill the bottles!
  12. Aladin Sane
    1,060
    99
    Jul 3, 2008
    Iowa
    I refilled for a while, and still carry some for my lantern, but being able to run my high pressure stove off of my 2 propane tanks will be great next season.
  13. p
    p Active Member
    538
    127
    Jun 9, 2014
    If u have a lp outlet....it is an easy conversion for a Coleman road trip BBQ.
  14. lksdrinker
    202
    50
    Oct 15, 2018
    Sure...if I owned a Coleman Road Trip I suppose. Not sure if you mean liquid propane or low pressure, but I converted my coleman camp stove to use propane and use the high pressure line for that.
  15. rabird
    6,718
    307
    TX
    with an adapter you could hook up a distribution post, one with a hose connection.
    Add a spear/extension to the post and cram er in the ground, use the top connection for a lantern, a side one for a stove and/or Q
    ezakoske likes this.
  16. lksdrinker
    202
    50
    Oct 15, 2018
    Thats the best I can come up with in my head so far!
  17. p
    p Active Member
    538
    127
    Jun 9, 2014
    Coleman roadtrip sometimes are sold used for $20 (mine was free) since people often lose the regulator. The part to connect it to the LP of your pup is approx. $10.
  18. lksdrinker
    202
    50
    Oct 15, 2018
    Or I could keep using the stove I already own and converted to run off the propane on my pup. Not looking for a new way to cook but thanks.
  19. ezakoske
    ezakoske Active Member
    525
    75
    Nov 30, 2014
    Escondido, CA
    This is an interesting option! Has anyone seen an adapter (splitter) which would connect directly to the HP outlet? Essentially ending up with 2 HP ports without using the distribution post...
  20. Aladin Sane
    1,060
    99
    Jul 3, 2008
    Iowa
