Propane distribution post mounted to side of pup?
Discussion in 'Propane - Got Gas' started by lksdrinker, Sep 18, 2019.
  1. rabird
    6,720
    307
    TX
    like the add a tee
  2. lksdrinker
    lksdrinker Active Member
    202
    50
    Oct 15, 2018
    I think the best solution I've come up with so far appears to be using a combination of all this at the high pressure outlet of the pup. This would allow me to run one line to a camp stove and another to a lantern. Not sure its worth the effort or the cost though. Might just go for it one day.
    https://www.amazon.com/gp/product/B00KYDJ694/ref=ox_sc_saved_image_5?smid=AXO3Y8HYXC74B&psc=1
    https://www.amazon.com/gp/product/B01MYPBM2X/ref=ox_sc_saved_title_6?smid=AC10Z379VB228&psc=1
    https://www.amazon.com/gp/product/B01MDM6T28/ref=ox_sc_saved_title_4?smid=AEEHSY4PP1735&psc=1
  3. rabird
    6,720
    307
    TX
    ezakoske likes this.
  4. lksdrinker
    202
    50
    Oct 15, 2018
  5. ezakoske
    ezakoske Active Member
    525
    75
    Nov 30, 2014
    Escondido, CA
    Neither did I - I think the caps threw me off...That's pretty much what I'm looking for - Thanks!
  6. lksdrinker
    202
    50
    Oct 15, 2018
    so I went with the adapter and the Y as that was cheaper than the add a tee. While it worked fine for running 2 stoves (at once and independently), it did not work for running a lantern. Seemed like there just wasn't enough pressure running through the line. Has me kind of stumped as I see no reason why it shouldn't work for a lantern?
  7. Sneezer
    1,547
    543
    I have two Y adapters that I use, one that goes inline between the Acme fitting and the tank, and then a 2nd that screws onto it to provide for 2 extension hoses. This allows me to run my HP stoves. However, I did convert my Weber BBQ, Road Trip, Weekender and soon my Blackstone Griddle to the LP port, and I built a Y-adapter with quick connects for it so I can run 2 off that port. I haven't tried the lantern on the hose though - next time I have mine out I will try and remember to give it a shot. I still like to have at least one HP stove as the LP ones don't like the wind that much.
    I did pick up one of those 4lb lpg tanks though, and it has come in real handy. I use it for tent camping, and often toss it with the pup to give me additional propane outlets wherever I may need them. The few times I do take the lpg firepit it is nice to just set the tank over there and hook it up, along with the tree and a lantern up top.
