propane firepits
jmkay1
2004 Fleetwood/Coleman Utah
8,054
I just look at mine and rejoice in the fact that a turn of a dial turns it off and I’m not moving my chair due to smoke.
i just bought and tried mine at the last campground and I was facing more wind than I usually felt comfortable burning a real fire with. I was hesitant to try the propane pit but was very surprised. The flames didn’t bounce around much at all or blow out. It stayed a continuous steady flame. Even more it was a first time I didn’t have to play ring around the fire trying to keep out of the smoke trail. Like you said no having to find someone to babysit a fire if i needed to step away. It’s going to take getting used to hearing the continuous hiss and the woosh of fire as you light the pit And the heat output. Best part I got to drive past those expensive moist bundles of wood sold.
Sneezer
3,087
Is there a secret to doing marshmallows on these things? We bought the Costco one, but every attempt to roast marchmallows ended up as a tiki torch, no matter how careful we were. What's your secret?
I just keep them a little higher so they get the heat but below burning, then I dip it lower to get a good char. You can't have a roasted marshmallow without a nice char on it. Something about blowing out the flames and eating it makes it taste better to me.
Karey
111
Colorado
All the propane fire pits I've seen require no power. Just a gas line to an LP tank. I did use our Little Red Campfire with 1# propane, with a "steak saver" adapter, but it gives more even flame with a bulk tank. Now that we have space in the truck bed, we take an extra 20# tank; I just bought a 1 gallon tank to use with it or my single burner stove.
This is off subject but your post reminded me . . . I got a 1 gallon tank after you talked of it somewhere else, but I bought the wrong 'cord'. It's missing a little center piece that all stoves have/need. Was disappointed last camp trip. Now back to the research. Maybe you have a handy link to the cord you got to go from the one gallon tank to your stove. Also, did you find a grate to use on your firepit? I want to try that as well
theseus
Living the Darkside...
Silver Supporting Member
Feb 6, 2007
3,575
Centerville, OH
You are looking for something like this
SHINESTAR 6FT Braided Propane Hose Adapter with Gauge, 1lb to 20lb Propane Adapter for Coleman Camping Stove, Blackstone 17/22 Inch Griddle, Weber Q and More https://a.co/2GkBS0R
kitphantom
Platinum Supporting Member
14,121
The first hose I bought didn't connect to the single burner stove I'll mostly use the small LP tank with, but the second one did. (I ended up with this one: )
The hose that came with our Camco Little Red Campfire connects to any size LP tank, as is. TO use that with the 1# propane thaks as we did at first required something called a Steaksaver.
I did buy a sort of grate to use with the LRC, it was made by Camco and they also make one to use with their larger propane pit (F4X589VZOTS&keywords=camco+fire+pit&qid=1663374900&s=sporting-goods&sprefix=camco+fire+pit%2Csporting%2C182&sr=1-20) I don't know if either fit other prpane pits. I planned to use ours mostly if I ever needed to actyually cook on the LRC, but we now have enough redundancy of cooking options on any given trip that it hasn't come up again.
Karey
111
Colorado
Sorry Andrea, but it doesn't show up in your post. I realize you are out camping now.
kitphantom
14,121
Maybe this will work, it's the one for the Little Red Campfire. (The internet at the KOA is working pretty well this morning, we'll see how long that lasts!)
OTR1522
Jun 9, 2018
74
If you can’t find the correct hose check out propanegear.com- they have all kinds of connections and hoses- bought a quick connect and longer hose to add to our fire pit- works great
