Propane Furnace Turning on when towing...
Discussion in 'General Camping Discussion Forum' started by leahdan, Jun 16, 2015.
  1. leahdan
    leahdan New Member
    29
    Mar 21, 2015
    So my dh encountered this when he picked our pup from storage, but we haven't solved the mystery yet and I'd love some insight/thoughts/suggestions before we take it out this weekend.
    The pup was stored without it's battery, but the propane was still attached (and apparently not shut off). When dh hitched it up to our tv - he connected the electrical and the camper furnace turned on! The pup was closed up and he immediately shut the gas off but it took quite a while for the fan to shut down. My theory is that our thermostat must have moved during transit or from storage to our tv, to the on position. Our thermostat does not have an on/off switch - just a moveable temperature gauge. Also I guess the furnaces use electricity to run the fan (ours growing up did not), but the camper was down so shouldn't the kill switch have not let this happen?
    How can we stop this from happening in the future? If dh hadn't caught it or it happens while we are on the road I fear our pup would end up in a ball of flames at the side of the road...
  2. rob2218
    rob2218 New Member
    1,549
    Feb 25, 2014
    HOLY cOW!.....the furnace turned on? and was the pup closed? well, I suppose so cause you were towing it right?
    geez...
  3. crosbys2008
    crosbys2008 Active Member
    859
    151
    Sep 2, 2013
    Erie, PA
    Your thermostat probably does have an off switch. If you slide the dial all the way down it will click over/slide over a hump which turns it off. I didn't know about it until it happened to me last year.
    --Rob--
  4. leahdan
    leahdan New Member
    29
    Mar 21, 2015
    You are right - it is off when the temperature is all the way down but there isn't anything to keep it there (no hump to pass over to hold it off).
  5. Yak
    Yak Well-Known Member
    1,205
    89
    Apr 18, 2009
    Slide it hard, mine was tough to get past the hump, I thought it was going to break. I upgraded to a digital with a battery
  6. leahdan
    leahdan New Member
    29
    Mar 21, 2015
    Thanks! I'll give it a try. Fingers crossed that's all it takes :)
  7. HLFAHEMI
    HLFAHEMI New Member
    Jul 18, 2014
    My 08 Rockwood does that when I connect the battery the first time in the spring.
    I have tried and tried to figure out why. The thermostat toggle is all the way to the min setting. It can't go any farther. My only theory is that it's some sort diagnostic or some such cycle. It doesn't turn on like that again unless I disconnect power completely and hook it back up. Also, when it does this I have never heard the igniter activate either.
    Sent from my iPad
  8. rabird
    7,418
    604
    N. TX
    I'd wire the furnace or thermostat through the kill switch.
    My water pump was not and a bump caused it to come on [:(O]
  9. natty bumppo
    natty bumppo 2009 F-150,1998 Coleman Westlake
    436
    Jun 22, 2008
    Pilot Moutain,NC
    My nephew's Starcraft has a switch on the swing up galley that makes the circuit to the furnace. This insures that the furnace will not come on when the camper is down. I'd think you may have a faulty switch somewhere thats not breaking the circuit when down.
  10. clydee
    clydee Member
    70
    Dec 9, 2014
    or the switch is working, but packed to the gills with something that puts some pressure on the switch ?
  11. leahdan
    leahdan New Member
    29
    Mar 21, 2015
    Thanks everyone! I took a much closer look at the thermostat while we were camping this past weekend and found that if pushed hard enough, it does switch off!! I had to take the faceplate off to figure this out lol). I think the furnace must not be wired through the kill switch. The kill switch is working fine for the lights, etc. when I tested it and the pup was empty when we stored it.
    I'm glad to hear that this also happens to another when picking it up from storage - now that I've found the off switch for the thermostat, I'm not so panicked that it will just randomly start when we are en route somewhere.
  12. Keith Hawkins
    Keith Hawkins Active Member
    1,336
    Mar 8, 2015
    The good news is, the propane is usually connected to the kill switch. So, even if the furnace did come on, it would not ignite.
  13. daschnoz
    daschnoz Active Member
    273
    56
    Feb 9, 2015
    If it comes off easily, take off the furnace grill. The furnace in my PUP has an on/off switch on it under the grill.
  14. Customer
    Customer Well-Known Member
    2,435
    248
    Jun 5, 2014
    I've never seen that. In order for that to be true it would require a solenoid controlled valve to be in the propane line. I've only seen that on a few motor homes, never on a small trailer.
  15. leahdan
    leahdan New Member
    29
    Mar 21, 2015
    I will take the furnace grill off and check for a switch when I have it up next week to pack for our next trip - that would be very functional if it did! Also our grill rattles something fierce when the furnace fan is on so I'll try and address that at the same time :)
