propane tank bracket?
Discussion in 'Miscellaneous Repairs & Maintenance' started by Jean-Paul, Jul 7, 2019.
  1. Jean-Paul
    Jean-Paul New Member
    28
    Jul 7, 2019
    The jayco qwest doesn’t have much to work with. 2 holes in some angle iron. Anyone know what is supposed to be used to attach a propane tank ?
  2. PopUpSteve
    PopUpSteve Administrator
    18,907
    1,650
    Dec 22, 2002
    Malvern, PA
    Jean-Paul likes this.
  3. nineoaks2004
    7,385
    3,143
    Dukes, Fl
    some use the holes on the bottom of the bracket it is sitting in and line up with the holes in the bottom of the tank then use nuts and bolts to secure the bottle.
  4. Jean-Paul
    28
    Jul 7, 2019
  5. Jean-Paul
    28
    Jul 7, 2019
    I contemplated that. I bought a battery tie down thinking I could go from the front to the back. But oops the tank bulges down so a straight rod won’t make a clear shot front to back. Bolts and butterfly washers will likely be the solution. Thank you
  6. TheBlurb
    TheBlurb Member
    36
    Mar 28, 2019
    My Qwest has the same setup. Two bolts with lock washers is all I use. Works great.
  7. joet
    4,762
    961
    Even the new small Jaycos use the bolt on method. I don't like this mounting as the tank will rock
  8. Snow
    10,186
    1,089
    Tank wont rock if the bolts are tight... My pups tank mounted that way and my parents old TT mounted the same way and it was towed all over Ontario, Quebec, UpState N.Y and most of the Canadian East Coast..
    Jean-Paul and xxxapache like this.
  9. PopUpSteve
    18,907
    1,650
    Dec 22, 2002
    Malvern, PA
    myride, Jean-Paul and xxxapache like this.
  10. Wrenchgear
    3,287
    579
    Aug 5, 2010
    5 Star Eagle Camper
    Cut a piece of ply wood to put in there to stand the tank on. Put some 'J' hooks on it to hold the tank down.
  11. joet
    4,762
    961
    Look at the newer Jaycos, when filled they will rock even with the bolts tight. We see this every day they don't sit flat on the angle brackets
