Propane tank trouble
Discussion in 'A-Frame PopUps' started by Tom and Teresa, Aug 3, 2021.
  1. Tom and Teresa
    Tom and Teresa Member
    94
    84
    Jun 18, 2019
    Shenandoah Valley, Virginia
    We are leaving soon to go out west to Yellowstone and other areas…love our Rockwood A-frame. So much fun when we went to the southwest in 2017. The one thing we’ve noticed this year is that when one gas tank is empty, it doesn’t automatically switch to the other tank. We have to switch the tanks around as when either tank is on one certain side, it won’t work. We figure a blockage of some sort…anybody else ever have this happen? Thanks friends!
    DiamondGirl likes this.
  2. Sjm9911
    10,628
    8,010
    Dont know, maybe a picture of what you have for a regulater will help. They have autochangeover ones and ones that dont do it automatically. Who knows what one you have. Someone will sort it for you.
    Econ likes this.
  3. Rik Peery
    Rik Peery Well-Known Member Gold Supporting Member
    1,607
    2,168
    Jun 15, 2018
    Virginia
    No help here, but hope y'all have a great trip! Keep us posted w/ pics etc...
  4. Sjm9911
    10,628
    8,010
  5. Jkoht
    Jkoht Member
    95
    75
    Aug 10, 2020
    Do you know if you actually have an automatic changeover regulator? In my experience they haven't come standard on trailers, just manual changeover ones. I had to buy one for my dad's trailer and install it for him.
    Allamakee County and DiamondGirl like this.
  6. Snow
    11,801
    2,380
    Until I joined this forum way back when, I had never heard of a manual change over dual regulator.. every dual setup I had seen and used was an automatic change over..
    kcsa75 likes this.
  7. DiamondGirl
    DiamondGirl Adventures with KODI in AZ
    1,114
    1,089
    Jul 2, 2016
    AZ
    On my Aliner Classic, we had to physically turn the switch over to the full tank side. It wasn’t automatic. Plus if it still doesn’t work, you may have to turn the propane off, remove the lines to reset the diaphragm and then reattach the lines. This has worked for us with the Aliner, the propane fire pit, grill, and now with KODI.
    Happy Camping…[put&hy]
    Allamakee County and Hilldweller like this.
  8. SteveP
    2,257
    931
    When I upgraded to two tanks I started out with a regulator that looked like this
    After about a year I could see mold growing inside the knob and the changeover began sticking. I would have to manually switch to the second tank almost every time for a couple of years. Then twice I had to swap the tanks from one side to the other, which is a pita with the bunk out.
    I replaced that regulator a Marshall Excelsior, a little more pricey but a good reputation. I wish I could give you a glowing review but I haven't been able to use it enough so far. The one time it changed over I didn't even notice until takedown.
    Econ likes this.
  9. kcsa75
    5,203
    3,238
    Sep 9, 2013
    Kansas City
    Do some wintertime camping and you'll learn about propane, especially when you have the furnace going and run out of propane at 3 a.m. ;)
    neighbormike, Westcoast and Sjm9911 like this.
  10. Sjm9911
    10,628
    8,010
    Lol, i only would have voltage hook ups, and the ellecteic heaters would do fine. I do want to test the heated underbelly of the camper though. I will fill the duel 30 lbers soon.
  11. Old_Geezer
    Old_Geezer Well-Known Member
    2,760
    505
    Sep 29, 2009
    Southwest PA
    Rockwood / Forest River uses the cheapest regulators they can lay their hands on. Get a Marshall MEGR-253H.
    Also, if you have ACME fittings on the pigtails remove the check valve ball that is inside it. Stupid gubmint regulations forced the manufacturers to install the idiotic thing and you already have safety features built into the tank valve.
    They can play havoc with auto change regulators. Most you simply pry out with a pick, or use a pair of pliers to remove the brass nipple in the picture, then the check valve ball and spring pop right out. Just press the brass nipple back in. I've seen a few that screw out, in that case visegrips.
    rmihalcin, Westcoast and Econ like this.
  12. Econ
    Econ Well-Known Member
    1,483
    911
    Aug 18, 2019
    Deep South
    We use minimal heat so never had a tank "change over" except once. Low tanks are caught in preflight or post flight inspection and dealt with except once. That was when a pigtail developed a leak and drained the tank then with the auto change over it drained the other tank. 40 pounds of propane. I personally wouldnt get another "auto change over" unless in Canada, etc. How often do you "run out of propane at 3 AM"
    @Tom and Teresa
    Personally I would replace the pigtails. Problem solved
    My regulator and pigtails only lasted about 5 years. How old is yours? Spray some soapy water on your regulator.
    Susan Premo and Sjm9911 like this.
  13. kcsa75
    5,203
    3,238
    Sep 9, 2013
    Kansas City
    It only happened to us once. Now I only leave one tank is open at a time. That way when the missus wakes you up in the middle of the night, you have a quick fix and it only interrupts your sleep for five minutes. Get the empty refilled and you're good to go again.
    neighbormike, Susan Premo and Econ like this.
  14. Econ
    1,483
    911
    Aug 18, 2019
    Deep South
    We turned one pigtail off so no more lost both bottles because it changed over. Some one lent us a bottle for the night. Felt obligated to make sure it was topped off. Spent 5 hours the next day driving into town finding someone who will partially fill his bottle.
    DiamondGirl and kcsa75 like this.
  15. Susan Premo
    Susan Premo Well-Known Member
    629
    337
    Nov 5, 2020
    Minnesota
    Wow, great info! We have that, the woman we bought our aliner from really seemed to get good quality stuff. So many things that everyone talks about are in it. Pretty good for a bit of an older model. 2011.
    DiamondGirl and Sjm9911 like this.
  16. Tait
    Tait Active Member
    106
    99
    May 1, 2020
    I second the preference for manual change over… It's much better to run out of the first tank unexpectedly and still have a second tank then to run out of the second tank unexpectedly and be out of propane… Particularly in the middle of the night!
    kcsa75 and neighbormike like this.
