Propane venting from regulator
Discussion in 'First Time & New Camper Owners' started by Mtlangst, Jul 9, 2019.
  1. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    so I set up my outside gas grill for the first time. I turned off the valve for the gas line at the grill and not the bottle first. When I went to the front of the camper there was propane venting from the regulator. Was that because I didn’t turn off the gas at the tank first?
  2. joet
    4,412
    810
    No, replace the regulator
    WVhillbilly, Sjm9911 and PopUpSteve like this.
  3. Raycfe
    14,743
    1,230
    Replace the regulator ASAP
  4. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    So any to stage regulator would work?
  5. rabird
    6,582
    258
    TX
    2 stage RV regulator, they come in vertical and horizontal models
    any RV store will have them
  6. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    Later after that i turned on the tank and sprayed the regulator to check for leaks and found none. So why would it have vented earlier and i smelled gas earlier while using the outside grill and not when i just opened the tank later?
  7. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    This is the regulator
  8. rabird
    6,582
    258
    TX
    never seen anything like that pictured!! What make/model. Any markings on 'regulator'? Any other regulator at the propane cylinder? What does the other side of the reg look like?
    There is a diaphragm in a regulator that moves in/out and need to be vented to the atmosphere via a small hole during use. If this diaphragm goes bad then propane vents out the little hole/vent.
  9. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    2011 rockwood freedom 1970
  10. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    This is the other side and it didn't vent later when i only turned the tank on to check for leaks.
  11. Sjm9911
    3,945
    1,960
    You sure the leak was from the regulator and not from the outside stove line that was just traveling to the front of the pup? I would check the whole line just in case.
  12. rabird
    6,582
    258
    TX
    ya might remove the plastic protective cap and see if there is any markings on the regulator, make/model etc. It sure looks odd to me for a PU
  13. tfischer
    tfischer Well-Known Member
    3,418
    934
    May 21, 2014
    If you are sure the gas was coming from the regulator, replace it. Now. It's not worth putzing around and figuring out why, as this is a very dangerous situation.
    Fixitup and DigitalGuru like this.
  14. Mtlangst
    Mtlangst Member
    70
    Jun 14, 2019
    424nrv is the model number. Can you replace with and two stage regulator?
  15. rabird
    6,582
    258
    TX
  16. DigitalGuru
    DigitalGuru Active Member
    525
    28
    Jul 5, 2011
    Michigan
    Regulators go out fairly often. If I had to guess that is an auto-changeover regulator as there is no switch to change which tank is being used. You can replace it with the same if you like, or some like a manual changeover so they know when one tank is dry. Flip the switch to the other tank, and take the empty to get refilled. Just an FYI; refilled propane tanks are 100% full while exchanged tanks are only about 80% full. My local Ace hardware fills a 20# for $10!
