PUP Information Tag Missing
Discussion in 'Miscellaneous Repairs & Maintenance' started by bruceac1, Jul 30, 2011.
  1. bruceac1
    bruceac1 Member
    57
    Mar 19, 2011
    El Paso, TX 79924
    I have a '87 Palomino TXL. The tag / plate giving GVW and stuff like that, is not mounted on the side of the pup. Is there another place it should be or located? I wrote / emailed Palomino and all I got back was that the records for that time period were destroyed in a fire and that the lady thinks the GVW might be 2500#. If anyone can relate what is on the nameplate, it would be greatly appreciated.
    Bruce
  2. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    I would try searching online with the model number or maybe the title lists the weight?
    If Palomino can't look it up via the VIN number then I would weigh it at the scales and see what the empty weight is. Not sure what else to suggest.
    You do have a title & VIN number, correct?
  3. kitphantom
    12,192
    1,207
    The only thing we found on our '84 Palomino was a metal tag on the tongue/A-frame with the VIN & model number scribed onto it. I don't think it has the weights on it, I can't get to it enough to read it at the moment, since it is popped up.
  4. rabird
    7,138
    479
    N. TX
  5. Miller Tyme
    Miller Tyme N. Fond du Lac, Wis.
    175
    Jan 7, 2003
    North Fond du Lac, Wisconsin
    My '85 Pal also had a plate on the A-frame, inscribed with the model, VIN and weight. As your TXL is the 14 ft. model, what you were told by Palomino is close to correct at 2500 lbs. My 12 ft. MXL was stickered at 2000 lbs. HTH.
  6. bruceac1
    bruceac1 Member
    57
    Mar 19, 2011
    El Paso, TX 79924
    Thanks very much for the info. I figured that it was under 2K when I brought it home with my Explorer and I barely knew it was there. When I looked at the registration papers there were no weights listed. The only thing I looked at when I was on the NADA site was the current listed price. It wasn't until later I found that I was missing everything else.
    Thanks again for all the replies.
