PUP, Tongue Weight, & rear sagging
Discussion in 'Tow Vehicles, Hitch & Towing' started by Dammitjim, Aug 30, 2011.
  1. Dammitjim
    Dammitjim New Member
    485
    Jul 20, 2011
    I have a Honda Odyssey 2005 EX-L towing a 2002 Jayco Eagle Summit 10SG. From the picture below, does it look like it's properly set up? This is a picture with it fully loaded. I didn't have any problems whatsoever towing.
    Uploaded with ImageShack.us
  2. RhinoDave
    RhinoDave Active Member
    2,317
    Oct 29, 2008
    Lake Orion, Mi.
    I've seen far worse. You are fairly level and even though your TV looks a little rear end heavy, if it tows well and still has good suspension reaction, I wouldn't worry about it. You might benefit from a set of air bags to help the suspension if you think it's a little too low. If it was my setup, I would add the airbags but I'm a little anal about the PUP being absolutely level during transit.
  3. Dammitjim
    485
    Jul 20, 2011
    Just curious... would a WDH help me instead of the airbags?
  4. joet
    4,702
    926
    IMO before I would invest in a WDH, I would check a couple of things, will the pup and the TV accept a WDH? what is the tongue weight of the pup?, is it within then the TV limits? AIR BAGS will not move the weight forward, only raise the rear of the TV.
    You are not that far from perfect
  5. airmech2210
    airmech2210 Member
    119
    Apr 15, 2011
    I don't believe the Odyssey is rated for a WDH. You should confirm that before you go that route.
  6. Dammitjim
    485
    Jul 20, 2011
    airmech, thanks for the heads up. The Honda manual actually states that one should use a WDH and sway bar when towing.
  7. Unstable_Tripod
    14,279
    30
    May 20, 2008
    Seattle, Washington
    Check the PUP's manual. The tongue on some PUPs is not rated to handle a WDH.
  8. Dammitjim
    485
    Jul 20, 2011
    Unstable Tripod, thanks for the heads up as well. I know that my PUP recommends for a WDH on page 11 of the owners manual.
    So, again, will a WDH be a good solution for the front being lower?
    As JOET said... I might not even need to do this, but wanted to know the options.
  9. airmech2210
    airmech2210 Member
    119
    Apr 15, 2011
    The airbag option will help lift the rear but the WDH is probably the best choice overall.
  10. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    I would do the air bags, If you have rear coil springs air lift makes a kit where the bags fit inside of you springs. It's a really simple install that works great.
    From the pic you don't look very far off to start with.
  11. gec66
    gec66 Active Member
    911
    36
    Sep 24, 2010
    I am pulling a much heavier pup than you with my Ody, but IMHO before you decide wdh or air bags take it to a CAT scale and get the weight on each axle. Only then will you know if you need the wdh. Air bags only correct ride height and will not correct the scenario of an overloaded rear axle on the van.
  12. West Coast Canuck
    1,637
    55
    Mar 3, 2005
    You could also reverse the draw bar and put the ball on the otherwise to lift the tongue higher. I did this on my Dodge Caravan because I found the tongue too low
  13. LBL 1206
    LBL 1206 New Member
    35
    Jul 6, 2011
    I did the same thing. Works just fine.
  14. Dammitjim
    485
    Jul 20, 2011
    That's a great suggestion! I don't think I can do it with the draw bar I have now because the ball is crewed in there permanently, but I could probably purchase another one for cheap.
  15. EvilM0nkey
    EvilM0nkey Camping fo free!
    217
    Jan 11, 2011
    Although it may not look like it. The van is already on the bump stops. Take a look under it next time and you will see. Those vans can hit the bump stops in the rear unloaded with normal driving.
  16. Dammitjim
    485
    Jul 20, 2011
    Where can you see those bump stops? Would driving feel different if that was the case?
  17. dgeddes
    dgeddes Member
    181
    Nov 13, 2010
    If both the TV and the PUP will take a WDH, I would invest in that.
  18. Storm Trooper
    3,544
    Feb 14, 2008
    Dammitjim,
    I believe you have already answered the two main questions.
    Your Honda recommends a WDH and so does your pup.
    You've got your answer. And yes with a properly setup wdh it will transfer weight to the front end of the TV and level it.
    One last question is whether or not you have a class 3 or better hitch on the TV.
    You can't use a wdh with a class 2 hitch.
  19. Dammitjim
    485
    Jul 20, 2011
    It's a class 3 on the TV.
    Yeah... I'm getting a WDH.
  20. EvilM0nkey
    217
    Jan 11, 2011
    I always saw it on the lift while servicing them, you may be able to crawl under the back and look with a mirror?. Just about every Odyssey (generation 2 and up) have a nice clean or even bare metal spot on the lower control arms inside of the spring where the bump stop is constantly rubbing. But I will say the bump stop is softer than most and about 4 inches long so it does act as a air bag of sorts.
