Push Rod
Discussion in 'Lift Systems' started by Kenneth Alicea, Jul 11, 2019.
  1. Kenneth Alicea
    Kenneth Alicea New Member
    Jul 11, 2019
    Hi all, I just wanted to ask everyone. My push Rod won't retract on my 1996 Jayco1207 used. Has anyone had this problem? And what did you do to fix it?
  2. joet
    4,965
    1,057
    What are you calling a push rod?
  3. Kenneth Alicea
    Jul 11, 2019
  4. thelmuth
    thelmuth Member
    114
    19
    Nov 6, 2015
    Brooksville, FL
    I'm assuming the roof is stuck up and not dropping in one corner. Is that your issue?
    Is the cable getting slack where it attaches to the push rod? If it is not, check the cable path and look for a bind. I had an issue with mine where the plastic pulley for the cable split and the cable got pinched in the Pulley. My cable actually broke because of it.
    If the cable is slack it may be catching on the floor bracket. There is a small gap between the floor bracket and the curved bracket.
    Hope this helps.
