Putting a lift on the pop up for higher ground clearance
Discussion in 'Miscellaneous Repairs & Maintenance' started by CasaBlanca, Sep 21, 2019.
  1. CasaBlanca
    CasaBlanca New Member
    17
    Sep 20, 2019
    Hi y’all!
    What are the things I noticed about my need to be camper is it sits really low to the ground which I guess is pretty normal so I thought we put a lift on our truck so I cannot put a lift on my camper? Has anyone done this before? Looking for all advice.
  2. GrueMaster
    GrueMaster Active Member
    184
    60
    May 22, 2013
    Saint Helens, Oregon
    Depending on the camper, a lot of people here looking to do the same thing have flipped their axel from on top of the springs to under the springs. Some trailers it is simple, some require a kit. Check around and you will find threads on this process along with before & after pictures.
    CasaBlanca likes this.
  3. gladecreekwy
    898
    1,134
    Sep 25, 2016
    Jackson Hole
    Many threads on this topic. Most pups sit way too low for any kind of travel on rough roads. Nice to move up a couple of tire sizes as well
  4. Aladin Sane
    1,083
    110
    Jul 3, 2008
    Iowa
    If you have a dexter torsion axle, they sell a lift kit for that. We added one to our starcraft highwall. It made a huge difference.
  5. CasaBlanca
    17
    Sep 20, 2019
    Can someone recommend a shop in the houston area that can do this?
  6. Anthony Hitchings
    855
    378
    Mar 2, 2019
    do not literally flip the axle (its has "camber" in it), simply relocate it from above the leaf spring to below the spring. Add the necessary new "perches" to allow this to happen.
