Putting a sealant on the roof
Discussion in 'Roof/Floor Repair & Maintenance' started by Spot09, Jun 17, 2021.
  1. Spot09
    Spot09 Member
    38
    Jun 12, 2021
    Oshawa, Ontario, Canada
    I am located in Ontario and I am looking for a rubber paint/sealant to put on the roof of my Fleetwood Bayiner. What are the preferred products that we can get at Home Depot/Lowes/Walmart/Canadian Tire in Ontario?
    Thanks!!
  2. Adam H
    Adam H Active Member
    549
    227
    Aug 22, 2015
    Filon roof? I use SealKrete.
  3. Spot09
    Spot09 Member
    38
    Jun 12, 2021
  4. Adam H
    549
    227
    Aug 22, 2015
    Depends what you want. Liquid Rubber will sit on top of the roof and could (will) eventually peel. Sealkrete is thin like water, soaks in and will never peel. I have even mixed 20% white outdoor latex into the Sealkrete and it made my roof look like new. I camp in the desert a lot and and the sun is brutal to roofs...
  5. Spot09
    Spot09 Member
    38
    Jun 12, 2021
    I am first trying move all this caulking and it is tedious. I would like to have a nice clean surface to start. I am using a heat gun and scraper.
  6. Rottiegirl
    Rottiegirl Member
    42
    28
    Jul 18, 2019
    SW Pennsylvania
    I second the SealKrete. Mixed a quart with 1/4 cup exterior white paint. What a difference! Water beads up, and the color is so much whiter. You can go heavier with the paint but a little goes a long way. I applied 2 coats, and have plenty left for next year.
    Adam H likes this.
  7. McFlyfi
    McFlyfi Well-Known Member
    760
    459
    Aug 1, 2014
    Thousand Oaks CA
    That roof is an Alumi-Tite roof. It's 3 sections of aluminum, with the seams being covered by the roof rack rails. That roof leaked notoriously, hence, someone gooped something along the edges of the roof rack rails to keep the water out.
  8. Spot09
    Spot09 Member
    38
    Jun 12, 2021
    After I clean it all up, I will put some rubber tape over those rails. I don't think I will use the rails for anything.
  9. Spot09
    Spot09 Member
    38
    Jun 12, 2021
  10. rbtharb625
    rbtharb625 New Member
    Aug 10, 2021
  11. rbtharb625
    Aug 10, 2021
    Which color jug of Sealkrete? The original red label or the muti purpose blue label?
  12. Adam H
    549
    227
    Aug 22, 2015
    Red label
