PWM speed control for my Fantastic Fan
Discussion in 'Heating / Cooling Systems' started by Anthony Hitchings, Nov 6, 2019.
  1. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
    as suggested elsewhere, I did this mod, I bought two PWM controllers (1 for spare). Tested controller using a light bulb for a load, then removed fan face (shroud), tested PWM directly on fan, then swapped wiring over on the face (shroud) of the fan and installed PWM to shroud body , tested, reinstalled. Note that PWM output seems to not like a common negative rail. Its a PITA working overhead. I did shorten the knob and the potentiometer shaft. For the shaft - use a small hacksaw - do not use a Dremel - a Dremel generates far too much heat. Insulated spade connectors were used between the shroud and the fan body (and supply wiring). The rheostat speed controller is totally disconnected.
    Econ, PopUpSteve and 1380ken like this.
  2. bheff
    bheff Well-Known Member
    1,504
    915
    Feb 24, 2011
    NW Arkansas
    Forgive my ignorance, but what does this do? And why is it better than just the potentiometer?
    kennedyma likes this.
  3. nineoaks2004
    8,031
    3,578
    Dukes, Fl
    Looks good thanks for sharing
  4. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
    The PWM (Pulse Width Modulator) enables a speed slower than Fantastic Fan speed #1, In our Aliner even speed 1 - the slowest - is too fast most of the time. Actually, it replaces the original controller entirely. Full speed is still available. Its infinitely variable.
    Look for this on Ebay:
    6V 12V 2A 30W DC Motor Speed Controller PWM Adjustable Variable Driver Switch
  5. Econ
    Econ Well-Known Member
    665
    319
    Aug 18, 2019
    Deep South
    Would it lower amperage useage?
  6. bheff
    1,504
    915
    Feb 24, 2011
    NW Arkansas
    Neat idea. I have a fantastic fan but have never turned it on
  7. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
    Net energy usage will be lower using a lower speed - its that simple. Net energy usage will be less for the same speed because you have taken the (original speed control) wire coil load resistors out of the circuit.
    Econ and SteveP like this.
  8. matwiyj
    matwiyj Active Member
    158
    32
    May 17, 2011
    Winnipeg, Canada
    It would have the same result as a potentiometer, in that it can adjust the speed of the fan, but will be much more energy efficient. It basically switches the 12Vdc to the fan on and off very quickly (like, hundreds or thousands of times per second). When the fan is to be on at 10% speed, the 12V is switched to the fan for only 10% of the time. Using it would save battery power and avoid large and bulky parts like a potentiometer that can handle 2 amps.
    Econ likes this.
  9. Econ
    665
    319
    Aug 18, 2019
    Deep South
    @Anthony Hitchings
    Did your PWM bolt right up or needed modification. Mine came from Amazon and I see you are on line right now. The problem is the fan's panel is thicker than the threaded rod on the PWM.
  10. Econ
    665
    319
    Aug 18, 2019
    Deep South
  11. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
    Using a PWM means that you will use less electricity because you fan is likely to be run at lower speeds.
    As best I can remember - I shortened the shaft on the PWM potentiometer and (maybe) also shortened the knob, so that the fan might be left with knob in place when we close the roof of the Aliner. Previously, with the as-supplied after-market Fantastic Fan - we always removed the knob before closing the roof. And also removed the vent operating handle.
  12. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
  13. Econ
    665
    319
    Aug 18, 2019
    Deep South
    May I haved the link to the one you got?
    Thanks
  14. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
  15. Sjm9911
    6,877
    4,234
    Nice neat instulation. Good luck with it.
  16. Anthony Hitchings
    1,193
    555
    Mar 2, 2019
    we used in our Thanksgiving trip to and from the Tacoma area - it works real well.
  17. Econ
    665
    319
    Aug 18, 2019
    Deep South
