Q: Self-Stick Vinyl Install
Discussion in 'Camper Restoration Projects' started by KampFish, Jul 16, 2019.
  1. KampFish
    KampFish New Member
    Sep 12, 2018
    Hello, I am contemplating using self-stick vinyl tiles in my pop-up. However, I live in a cold climate (chicago) and I'm worried it may not hold up to the the swinging temperatures of winter and summer. Manufacturer's state not to use additional adhesive. Any advise? Thanks!
  2. Matt Benoit
    Matt Benoit Well-Known Member
    544
    335
    Jul 30, 2017
    Warren, MI
    I used the 12x12 peel and stick tiles from home depot. They were easy to install. But have shifted around now with large gaps between some squares. I think it was the extreme heat that softens the glue, combined with the flex of the camper floor. I won't use them again.
    Raycfe and KampFish like this.
  3. KampFish
    KampFish New Member
    Sep 12, 2018
    Thanks Matt, what did you use instead?
  4. Matt Benoit
    544
    335
    Jul 30, 2017
    Warren, MI
    I haven't redone the floors yet. Instead, we picked up 4 small bathroom rugs from bed bath and beyond. The rugs are much more comfortable to walk on, and cover almost every visible issue with the peel and stick floor. Ideally, I would use a vinyl flooring that snaps together like laminate. I've used the LifeProof flooring from home depot and it's very nice... And waterproof!
    jmkay1 likes this.
  5. Raycfe
    17,005
    2,587
    We had the same problem. Cover them with rugs that we could remove and shake out.
    Matt Benoit likes this.
  6. Matt Benoit
    544
    335
    Jul 30, 2017
    Warren, MI
    And wash! Lol
  7. Elaine Rowe
    Elaine Rowe New Member
    Jul 18, 2019
    I'm in Michigan - put the self stick tiles in my pup 3 years ago and they have never moved :) Camper stays outside during the winter too! We didn't use any additional adhesive and I didn't grout them in either, which you can do with special grout. We didn't bother, lol.
  8. Raycfe
    17,005
    2,587
    Just to add a good point about self stick tiles is they can easily be removed for repairs and then just a few new replacements would be needed.
  9. bheff
    bheff Well-Known Member
    1,504
    920
    Feb 24, 2011
    NW Arkansas
    Several have used peel and stick planks with great success. Just be sure the floor is absolutely clean and degreaser prior to placing the new planks.
  10. jon davenport
    jon davenport Member
    44
    56
    Aug 22, 2019
    Kansas
    If you take the time to make a paper template and cut it out of 1 piece of vinyl floor the results will make you happy and it is just as cheep or more so than peel and stick.
