Quality Cooler vs Refer?
Discussion in 'Heating / Cooling Systems' started by lynnmarie0123, Jul 1, 2020.
  1. lynnmarie0123
    lynnmarie0123 Active Member
    371
    80
    Jun 19, 2020
    Hi! Im new here!
    so ive got a Bazillion questions to ask and this is one of them!
    I just brought my new used pup home today. it has a nice Dometic refrigerator however my main interest is having ice and frozen goods. This one hasnt a freezer. Im vegan. I dont eat meat or dairy so no need to cool that stuff. Mostly i make protein smoothies and need ice for those.
    My camping trips are only going to be 2 dayers. I think I want to remove my Dometic refrigerator (and get more storage space) then buy a very good cooler, maybe a YETI; make a reflectix cover for it for extra insulation and just go that route. I could keep cooler on a bunk since its only me. Or in colder weather in my tow vehicle. From all I have read on here, refrigerators are just a huge pain. Plus my tow vehicle is only an SUV so not rated for lots of weight.
    i understand these high end high performance coolers can keep ice for several days at least. Thats all i want. If anyone has experience with these coolers id love to hear‼️ Thank you kind people!
  2. Sneezer
    2,734
    1,562
    There are cheaper options than Yeti. Look at Ozark Trail copies, or Aldi when they sell theirs. Many of the competitors get high marks, and I don’t see the need to spend the coin on a Yeti. Besides - start talking yeti prices and you are already pretty close to a clone of an ARB or Engel 12V compressor frdige/freezer, which would be way better than any cooler.
    I personally would keep the fridge if it is working. They do quite fine for basic needs, and with some simple mods (do a search) they do even better. Then get a decent cooler to handle your frozen stuff. Plan your meals to take advantage of thaw rates. I use my fridge on every trip, take a 2nd hybrid 12V/110V fridge for longer trips, and a 12V cooler for drinks when I need it.
    lynnmarie0123 and Old ackpacker like this.
  3. xxxapache
    3,875
    2,073
    Ain't no way I'd remove a good working RV fridge.
  4. Old_Geezer
    Old_Geezer Well-Known Member
    2,739
    480
    Sep 29, 2009
    Southwest PA
    RTIC is what you want......great stuff. Check the site every week and you'll hit a sale. They have sold the 65 in the past for $149.
    nectarsis and lynnmarie0123 like this.
  5. jmkay1
    6,662
    3,616
    I still use my fridge, but also still use a cooler. A fridge is a great way to keep drinks. That way someone isn’t constantly opening a cooler Causing it to lose its cool air. I also don’t want some of my food frozen, so put that in a fridge. I couldn’t lift a yeti cooler with ice/food not to mention cost. I found a good 5 Day Coleman cooler that with the combination of reflectix etc I can squeeze 5 days Out of if not more assuming I don’t constantly open it a lot. The key is to stay out of a cooler as much as possible the more you open it the more Warm air gets in and more ice melts.
  6. eoleson1
    eoleson1 Well-Known Member Gold Supporting Member
    3,542
    1,654
    Jul 5, 2011
    Macomb County Michigan
    When I had the popup, I didn't use the fridge on weekends. It took too long to.cool down and I couldn't preload it before we left without popping up the camper. I did use it on longer trips and it worked fine. They are pretty reliable in my opinion with a little maintenance. The biggest problem you have is spiders building a nest in the burner. That is usually a pretty quick fix.
    kcsa75 and lynnmarie0123 like this.
  7. nineoaks2004
    8,244
    3,713
    Dukes, Fl
    I have always used the reefer even without a freezer and a decent cooler but as stated there are cheaper options than a yeti, for trips of a couple of days a standard Coleman cooler would work fine, I made a cover from reflectix and use it, I also put a hasp and padlock on it due to the racoons helping themselves. I carried a dorm reefer for a long time and used it which worked fine, cooled quickly I am sure you can use the extra money saved for other needed camping items. Good luck and keep on camping
    lynnmarie0123 likes this.
  8. Steveo4090
    Steveo4090 Well-Known Member
    774
    724
    Jun 26, 2020
    Lancaster PA
  9. SteveP
    2,194
    887
    Keep the fridge, it's good for things you don't want to get soggy, such as greens and other veggies, +condiments, lunch meets, cheese. If you don't use it as a fridge you can store dry foods etc. in it to make them less attractive and accessible to vermin.
    If you don't prechill and preload the fridge you'll need a cooler for travel. We like having ice also but you don't need an expensive cooler for 2 days. Many coolers have little or no insulation in the lid. Before you buy the cooler tap on the lid and make sure you get a solid thunk, same sound as on the sides. Try to open it with the lid latched, if the lid moves it won't seal well.
  10. MileHigh
    MileHigh Active Member
    498
    114
    Jul 18, 2012
    Denver
    Yes - keep the fridge. You can still use it for storage even if you don't power it on. I keep cold drinks in my fridge and a few other food items.
    You will like a good cooler too. I bought a RTIC 65 a few years ago and it very useful. In Yellowstone, I didn't need to add ice for the entire week. In Utah last summer, I did need to add some ice but the temp's were well into the 100's. I bring 2 coolers with me - one for frozen foods and one for refrigerated things. I have added a layer of reflectix to the inside of both and that works wonders.
    HappyTraveler and lynnmarie0123 like this.
  11. Sjm9911
    9,714
    7,115
    Colman extream cooler. Like 40 $ . Works well. Its not a yeti, but islts also way cheaper. Look up cooler reviews on you tube , lots have hands on stuff to help you decide.
  12. Sjm9911
    9,714
    7,115
  13. Blackripley
    Blackripley Active Member
    218
    162
    Jul 21, 2018
    Goleta Ca
    Removing it would be an undertaking, and would hurt the resale value of the trailer. I would leave it as others have said. For us before leaving on a trip I but 2 frozen 2-liter bottles in the refrigerator to precool it. Without turning it on it makes an ok cooler (not great but ok).
  14. Wakita46
    Wakita46 Active Member
    270
    87
    Mar 15, 2013
    I took out my fridge because it was too small to hold much. A Coleman Marine extreme will hold ice for 5 days and hold a lot more stuff. Yeti's are overpriced and way too heavy. Unless you are worried that a bear is going to break into your cooler, I don't find the extra price and weight worth it. Just my 2 cents after 20 U.S. national parks and 15 Canadian national parks in my camper.
    towing12345 and lynnmarie0123 like this.
  15. Anthony Hitchings
    2,715
    1,511
    Mar 2, 2019
    Oakland, California
    if its a fabric sided PUP, in bear country your cooler , or at least its contents, will likely be required to be stored in on-site steel bear boxes.
    which gets interesting when you/we swap out a Dometic Frig for a portable cooler.
  16. lynnmarie0123
    371
    80
    Jun 19, 2020
    GREAT TIP THANKS!!!‼️
  17. lynnmarie0123
    371
    80
    Jun 19, 2020
    This sounds a perfect plan to me. Im not camping in high altitudes so i do need ice and insulation.
  18. lynnmarie0123
    371
    80
    Jun 19, 2020
    Nope not worried about Bears !! Lol and your advice is sooooo appteciated ✊‼️⛺️Not to mention the weight of it. My tow vehicle is not rated for alot of weight.
  19. lynnmarie0123
    371
    80
    Jun 19, 2020
    W
    WOW ‼️ Something else to think about. Lots to ponder here...
  20. lynnmarie0123
    371
    80
    Jun 19, 2020
    Thank you for this link⛺️⛺️⛺️⛺️⛺️
    nectarsis likes this.
