Question about power in my pop up
Discussion in 'General Camping Discussion Forum' started by samsquamch, Aug 23, 2021.
  1. F. Jake Glotz
    F. Jake Glotz New Member
    17
    Sep 1, 2021
    Some models have a Single pole thermal type breaker in line with the battery. They automatically reset, but can be a nuisance when the fail.
  2. RonDad
    RonDad Active Member
    115
    118
    Aug 11, 2020
    North Carolina
    No battery…start with the converter. Is it getting 110v? Is it outputting…anything? Is there a fuse before it distributes to the rest of the 12v circuits. Good luck.
  3. Memaw57
    Memaw57 New Member
    19
    Mar 16, 2021
    Took converter into an rv place and was no good. What would be the best replacement for outlets and 12v(interior lights). That's all I need a converter for
  4. tombiasi
    6,672
    2,239
    Just about anything that fits in the hole.
  5. Memaw57
    Memaw57 New Member
    19
    Mar 16, 2021
    It was a 30 amp. Do I need to go back to a 30
  6. Sjm9911
    10,776
    8,150
    If you want to power whats in your pop up, you probably need the same size converter. Note that the converter only converts 12v from 120. So the other stuff is the breakers on the side. Those are your outlets.
  7. popup-flyer
    popup-flyer Active Member
    255
    182
    May 11, 2021
    Central Texas
    I would suggest finding something that fits and assuming it also had your breakers for your 110 outlets as well as supplied the 12v to your campers additional features you look for one that can hold at least as many breakers and is rated similarly in amps as well as having 12V supply for the various 12V systems such as heater, lights etc...
    In other words look for a comparable unit to what you had so its as easy a replacement as possible. You might get the model info off of yours and find out what might be a direct replacement from a converter retailer.
    Lol I think SJM and I are in agreement there ;)
  8. Memaw57
    Memaw57 New Member
    19
    Mar 16, 2021
    Thank you
  9. WrkrBee
    WrkrBee Un-Supported Member
    6,569
    3,461
    A converter converts 120vac to 12vdc. An inverter changes 12vdc to 120vac. Big difference.
  10. Sjm9911
    10,776
    8,150
    Change "to" to "from" its late. Done.
