question about proper solar panel wiring
ricorob
New Member
Sep 11, 2014
Currently the +/- wires from the deep cell battery power everything in my popup camper. I've installed a 200w solar system. I've wired the system as show in the image except instead of the wires from the battery going to an Inverter, those 2 wires power the rv as normal. My question is should I power the rv only from the solar controller (ie remove the positive and negative wires from the battery and hook them up to the controller) or is it correct to have +/- leads going to the solar controller as well as leaving the exiting +/- leads that power the rv's systems?
http://i42.photobucket.com/albums/e333/ricorob/_57_zps21cd318a.jpg
bearman512
1,229
Albuquerque NM
NO do not go directly to the RV.
You must go from solar panel to solar charge controller to the battery in that order.
If you have a separate power line coming out of the solar controller then you can run a Inverter off of that.
ricorob
New Member
Sep 11, 2014
I've got +/- leads from the solar panels to the controller. +/- leads from the controller to my battery. Do I leave my existing battery leads that feed the 12v Dc to the rv on the battery or move them to the controller's DC output to power the existing electrical system?
bearman512
1,229
Albuquerque NM
Yes leave it as is.
