question for the A-Liner crowd
Discussion in 'A-Frame PopUps' started by bob barnes, Jun 19, 2017.
  1. ~erik~
    ~erik~ Active Member
    287
    49
    Jan 19, 2015
    North Georgia
    Same here, would like to view the files but get error mssg. :(
  2. Brian Hovander
    Brian Hovander Member
    62
    Sep 4, 2016
    Try this link: https://www.facebook.com/groups/Aliner/
    to access all my how-to articles or this below link to access the article on easily installing effective gas spring lift assistance:
    https://www.facebook.com/download/preview/244990656630578/
    The article has been thoroughly revised to show the improved method I am now using. After a lot of research and work the ultimate solution has been found and installed on my trailer. It builds on the work of others who have successfully installed the most successful gas spring solution.
  3. CivilizedOne
    CivilizedOne Member
    75
    42
    Mar 29, 2018
    Kentuckiana
    Anyplace where I don’t have to create an account?
  4. nhlakes
    nhlakes Well-Known Member
    657
    332
    Oct 15, 2011
    DE and NH
    PointyCamper likes this.
  5. Brian Hovander
    62
    Sep 4, 2016
    I evaluated all the methods for installing roof panel lift assisting struts. You might want to review my article. Several folks have scrapped the Aliner installation method. I tried the initially-vertical method and now I switched to the best method out there. Check out my article on installing gas springs (called How to Install Gas Spring Lift Assistance) in the files at:
    or directly at this link:
    I put a lot of work and expense into this article so others could benefit by my research, mistakes and finally great successes! Based on all the horror stories, I would never want an electrical powered roof lifting system when this system is so simple and works automatically. And you don't mangle your roof panels if one electric lift stops working or one wind cheeta strap activates in windy conditions or with the jerking motion of the roof panels when starting them up a second time.
  6. mark30
    mark30 Member
    31
    Jul 21, 2018
    Hi Brian, since the Yahoo group requires a login, can you post a copy of your article on this site?
  7. Brian Hovander
    62
    Sep 4, 2016
    Yahoo groups died! You can peruse or join a replacement group and within the files section of that group is one called "How to Install Gas Spring Lift Assistance". The group is at this link:
    This article provides the easiest and most effective method for installing gas springs.
  8. Brian Hovander
    62
    Sep 4, 2016
    The file is too large to post on this site. I started a new replacement group on Facebook where you can find this file. Facebook is better than Yahoo. Here is the link to the group: https://www.facebook.com/groups/Aliner/ Just look in the files section or go to this file direct at:
    Note that the former Yahoo group died as have all such Yahoo groups.
  9. Brian Hovander
    62
    Sep 4, 2016
  10. Brian Hovander
    62
    Sep 4, 2016
    Here is an article I just finished today on how to install gas springs to effectively aid in raising your roof panels. Hope it helps. See this file:
    or look in the files in this facebook group called ""
    Try this link to access the file:
    https://www.facebook.com/groups/Aliner/files/
  11. Brian Hovander
    62
    Sep 4, 2016
  12. Brian Hovander
    62
    Sep 4, 2016
    Note that all Yahoo groups died! The information is now on a Facebook group called "Aliner".
  13. Brian Hovander
    62
    Sep 4, 2016
  14. Brian Hovander
    62
    Sep 4, 2016
    This group and the files should be accessible to most folks without a need to join:
  15. Brian Hovander
    62
    Sep 4, 2016
    The above is the most current version that may appear detailed but was written to try to make it easy to install the gas springs.
