Question gas or electric
Discussion in 'Wiring' started by packofwises, Aug 2, 2012.
  1. packofwises
    packofwises New Member
    232
    Jul 17, 2012
    In an access panel outside of the put there is a mechanism inside that says electric or gas. Can all electric items be run from propane if there isn't any electric CG hookups?
  2. Raycfe
    17,005
    2,587
    Most likely you are looking at the refrigerator, propane or 110 VAC or 12 VDC, a water heater is usually only propane, and a furnace uses propane and 12 VDC. In summary you could run the water heater and refrigerator, but will need a battery to run the furnace fan and controls.
  3. singledad
    singledad New Member
    293
    Jun 5, 2012
    The fridge can, and the stove, but the furance needs 12v for the thermastat, and forget the A/C unless you have 2 - 3 batts and a way to charge them.
  4. teejaywhy
    teejaywhy Active Member
    1,411
    Jul 19, 2011
    The fridge is the only appliance that can be run on electric or propane.
  5. Unstable_Tripod
    14,279
    42
    May 20, 2008
    Seattle, Washington
    Those of us who dry camp and/or boondock use our deep cell batteries to operate the lights, water pump and furnace fan. The stove, fridge, furnace and water heater run on propane. Once you get used to the system and learn to be conservative you really don't need AC electricity.
    Yes, I know that some folks want air conditioning and that requires AC hook-ups or a big generator. I don't use air conditioning so I ignore it.
