Question: How often do you repack wheel bearings on your pop up?
Discussion in 'General Camping Discussion Forum' started by kmeece, May 9, 2013.
  1. kmeece
    kmeece New Member
    136
    Apr 19, 2013
    I was told that you should repack wheel bearings every year. Is that true? Is it hard to do yourself?
    [MOD]
  2. Unstable_Tripod
    14,279
    40
    May 20, 2008
    Seattle, Washington
    A lot of people do them every year but that may not be necessary if you only use it a few times a year on short trips. My TrailManor has 14" tires and the dealer said to do those every two years or 12,000 miles, whichever comes first.
  3. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    How often do you repack the front wheel bearings on your vehicle? (assuming it has conventional wheel bearings) Every few years is fine and you put many more miles on your vehicle. I've repacked the front bearings on my 2000 Ford Expedition 2 times in 150,000 miles. Never had any issues.
    I think the real problem is that many trailer axles come with very minimal grease at time of purchase. I've seen this several times.
    Every two years or 12,000 miles as mentioned above by UT should be fine. Every year is overkill unless you really rack up the miles in a hurry.
  4. daveo1289
    daveo1289 Active Member
    986
    85
    Apr 24, 2012
    Rochester NY
    The rule of thumb is 12k miles or two years. If you have grease fittings in the axles, give them a shot before every trip.
  5. f5moab
    1,421
    469
    May 7, 2013
    Somewhere in Idaho
    I'll do mine every year, but that is via the E-Z fill zerk fitting on the end of the axle. Just lift that wheel, pop off the cover, install grease gun and pump while spinning the tire. Clean up all the old grease that comes out the end of the axle.
    I'll probably pull the bearings out every three years and do a check of the bearings/races/brakes and repack.
  6. Rc_maniac
    Rc_maniac Member
    274
    Sep 15, 2012
    My trailer is about 3 years old. I've only had it a year, so i don't know how the PO took care of it. I recently had to take one side of the axle apart to fix a faulty brake wire that was shorting out against the backing plate. My bearings looked fine and had plenty of grease still all over them and this is 3 years we're talking. So as previously stated, a two year interval should be just fine. You don't have to disassemble them for greasing if you have a zerk fitting on the end of the spindle. You'll probably have problems with the brakes long before you have problems with the bearings. You'd be able to check the bearings easy enough when you service the brakes at that point.
  7. ridenred333
    ridenred333 New Member
    588
    Apr 23, 2013
    I havent done them since I have owned my trailer. Knock on wood no issues. I have taken it on many 500 plus mile trips and dragged it all the way across the country. I do need to do just haven't. Its not hard just a little messy.
  8. msuce99
    msuce99 New Member
    186
    Sep 7, 2012
    I asked the PO of my new camper and he hadnt changed the tires or packed the bearings since he bouught it off a dealer lot used in 2004. Two days after I bought it, I ordered new tires and wheels, and last night I ordered new bearing kits.
  9. No Place Is Home
    No Place Is Home New Member
    Jan 28, 2012
    The smaller the tire the more revolutions it makes per mile- translating to more heat. If you are running 8" wheels it makes sense to do them every year. 14" or 15" wheels can be done every 2 years.
    Of course if you don't use it much it can be stretched to longer intervals but when you're stuck on the side of the highway with the trailer wheel rolling past you, you will wish you had done the maintenance at home.
  10. T-Rex
    T-Rex Jesus Saves!
    23
    May 7, 2013
    If the wheel spins freely and doesn't make any noise, can I assume it's OK?
  11. mamabean5
    mamabean5 Well-Known Member
    7,254
    40
    Oct 7, 2009
    We do it every year. I'd rather be proactive and save myself headaches down the line.
  12. ghacker
    ghacker Active Member
    3,438
    Nov 8, 2009
    A better way is too monitor the temperature on a trip. Old way, put your hand on the hub. New way, use an infared thermometer from Harbor Freight (very accurate BTW). After a few trips you know what's normal in different weather. If you use the "old way", be careful. You could get burned if they are running hot. But normally bearings don't just start running hot right away. You'll notice a gradual buildup over several trips. I usually check ours while making a gas stop.
  13. T-Rex
    T-Rex Jesus Saves!
    23
    May 7, 2013
    That's a great tip thanks, ghacker!
  14. Geordie
    Geordie New Member
    May 6, 2013
    I use bearing buddies, a little messy but makes greasing a snap!
  15. popitup84
    popitup84 New Member
    78
    Apr 30, 2013
    i also have bearing buddies...i'm am a little unsure on one thing....when do you know its time to re-lube? new b question probably i know but i've been curious...
  16. T-Rex
    T-Rex Jesus Saves!
    23
    May 7, 2013
  17. f5moab
    1,421
    469
    May 7, 2013
    Somewhere in Idaho
    The new new way is an air pressure monitoring system that also monitors the heat inside the tires. If bearing start to heat up, air in side the tire will also rise. I just purchased the Tire Minder system and will install it this weekend. Monitors both air pressure and air temp inside the tire. So if pressure is high and ok, and the tire starts to heat up, something is wrong.
  18. CamL48
    CamL48 New Member
    1,420
    Feb 20, 2012
  19. Raycfe
    16,879
    2,478
    Bearing buddies on a PUP can fill the brake drums with grease .... a very bad thing. They are designed to force water out of the bearings, common problem on boat trailers, the grease then spins out all over the place. For those of you with bearing buddies, use caution. You may not have a problem but other may. We also always suggest the PUPs have brakes and they get used. Don't want to step on toes here. Sorry if I do, I am not doing it on to hurt anyone feelings. Just my 2 cents which isn't worth a nickel.
  20. jackk
    jackk Member
    102
    Aug 16, 2012
    Just did mine for the first time. Pretty easy. Get yourself some latex gloves, it's pretty messy.
