Question on Battery use of fridge when towing
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by jonkquil, Aug 14, 2019.
  1. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Vancouver Island, British Columbia
    I'll take a government website over an rv dealer association chart. Legal or not, I don't think the added risk is worth it. But to each their own.
  2. GreyFox
    GreyFox Well-Known Member
    2,027
    1,012
    Oct 10, 2018
    S Ontario
    Guess propane powered vehicles don't sell well in BC, eh? [LOL]
  3. Snow
    10,573
    1,341
    http://www.drivesmartbc.ca/rvs/operating-rvs-propane[/QUOTE]
    Not a .Gov website. It is run by someone as a hobby.. Much like this site is run by Steve..
    Yes to each there own.. But the chart from the RV Dealers Association is more accurate then the non=government link you provided..
  4. crackerJack
    crackerJack Well-Known Member
    1,177
    352
    Jan 6, 2014
    Scottsville, KY
    Correct, the batteries were not charging, but they were full and ready to go for dry camping.
    On that camper, the breakaway was tied directly to the positive post on the battery and not broken by the disconnect. I assumed it was still active, although I never tested it. ??
    Snow likes this.
  5. Annunzi
    Annunzi Member
    42
    Jun 14, 2019
    Yes to each there own.. But the chart from the RV Dealers Association is more accurate then the non=government link you provided..[/QUOTE]
    Okay I'll eat crow on this one, I reached out to the provincial regulator (Technical Safety BC, formerly BC Safety Authority) and they provided the same chart that Grey Fox previously provided. My apologies for stirring the pot and I'll make sure to better check my resources next time.
  6. Fless
    Fless Active Member
    961
    206
    Aug 14, 2012
    Colorado
    Refreshing.
  7. Fless
    Fless Active Member
    961
    206
    Aug 14, 2012
    Colorado
    Mind me asking what your "open gas tank" is, or looks like? Do you mean the propane bottle?
    _
  8. jonkquil
    jonkquil Active Member
    537
    48
    Jul 20, 2009
    Yes that's exactly what I mean. I thought that might sound confusing when I wrote it! (I'm a UK transplant so quite often use the wrong terms)
  9. BillyMc
    BillyMc Well-Known Member
    1,344
    691
    Mar 25, 2018
    My fridge pulls just under 10 amps, I'm assuming that's pretty normal for 3 way fridges. If everything is connected properly when you shut off the TV it should terminate the power to the 7 blade connector. Assuming you camper battery was fully charged when you leave the TV charging system should have no problem keeping up. If the TV charging system can't handle an additional 10-15 amp load it either has a problem or I'd be looking at upgrading my TV.
  10. Snow
    10,573
    1,341
    Not all 7 way plugs even from the factory are wired to kill the charge line voltage when the ignition is off.. My old GMC the line was "hot" all the time, wired that way from the factory.
    Or you need to see if an upgrade alternator is available for the vehicle.. 80% of all factory tow packages (and about 70% of all tow prep packages) come with a higher out put alternator because the dinky stock one is barely enough to run the vehicle when all electrics are turn "on".
    Spridle likes this.
  11. Spridle
    Spridle Well-Known Member
    1,133
    335
    Jun 6, 2011
    Assuming your alternator and wiring can put out max amperage - when your fridge is pulling 10A continuous and your battery also pulling X amps to charge up - you can overheat the RV plug. Which is how I ended up traveling on propane only.
  12. BillyMc
    1,344
    691
    Mar 25, 2018
    If the battery is fully charged it should be using very minimal if any amps to maintain it's charge. If you're overheating the plug you are pulling more than 10-15 amps. Install a 15 amp fuse or circuit breaker inline to protect the plug.
  13. Spridle
    1,133
    335
    Jun 6, 2011
    I chose to run on propane and know that the battery will be fully topped up by the time I get wherever I'm going or when I get home so I don't have to bother hooking up the charger. Although you are correct, the feed is frequently fused at 30A but the plug is only rated at 15A.
