Quick Connect Gas Line Splitter
Discussion in 'Propane - Got Gas' started by Sean W, Jul 23, 2020.
  1. Sean W
    Sean W Member
    33
    Aug 19, 2018
    Has anyone used a gas line quick connect splitter on their pup? Can you run two things from the split line at the same time, like a stove burner on one and griddle on the other? Would both devices receive the 11 WC of gas pressure after the split or would it be diminished to lower pressure?
  2. Sneezer
    2,856
    1,691
    I have one. I built mine from parts off Amazon. It has 2 quick connect fittings. I have had no issues running two burners off it at the same time. Usually it is a Weber BBQ and a Camp Chef Weekender stove, although I will be getting an adapter to run my Blackstone griddle off it as well. I thought about doing a 3 way but at the time I didn't have the need for 3, and it would have made the whole thing more expensive anyway. Not a huge chore to swap lines out, and I would rarely need 3 at the same time so it was more of a convenience factor than anything.
