Quickest way to remove your fold out steps.
Discussion in 'PopOut (Hybrids)' started by Old_Geezer, Oct 13, 2014.
  1. Old_Geezer
    Old_Geezer Well-Known Member
    2,689
    415
    Sep 29, 2009
    Southwest PA
    Back into the driveway without folding them in, they rip off the camper nicely when they come in contact with wall stones. Sorry, no picture of this mod.
  2. yetavon
    3,435
    239
    Mar 11, 2010
    Western NC
    I was afraid that's what happened....you can use a similar method to remove unwanted antenna's....
  3. Old_Geezer
    2,689
    415
    Sep 29, 2009
    Southwest PA
    [LOL]
    [LOL] [LOL] [LOL] [LOL].....It works well. I will give Keystone RV credit on the outriggers they mount to though, they hardly bent at all. The replacement will sort of be plug and play 4 bolt easy.
  4. shelmily
    shelmily Well-Known Member
    3,535
    475
    Jun 7, 2012
    Northeast Pennsylvania
    Man that really stinks. I caught a parking curb once with the popup. Those steps weren't coming off. It bent them up quite a way. Luckily I was able to straighten them out and repaint them good as new. How did the stone wall make out?
  5. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    Sorry to hear of your SHT (Stupid Hybrid Trick). I've often considered changing my steps out for a 3-step version, as we have had several times where we were off level to the right and had to lift the right side up a lot. Only thing is, not sure how close it'd get me to the ground, and I can't risk that!
    Where did you find the replacement steps, ebay? Did the factory ones unbolt easy, other than the damage and bent mounts?
  6. Old_Geezer
    2,689
    415
    Sep 29, 2009
    Southwest PA
    Kevin, they were made by Hickory Springs Mfg, you can find them all over the place on the web. Around $120 or less so no big deal although I have also found them way overpriced at places. The 3 step version popped into my head immediately, but the entire 2 step assembly is 25 1/2" overall, the 3 step version is 27 1/2" overall. Keystone or LCI welded the mounts to frame to accomdate that 25 1/2" and like you said what happens if you're on a site that's high in the front? To install the 3 step version I'd need to grind off and re weld one of those plates, or both if I wanted them centered on the door. They are bolted to the welded mounts with 4 bolts. Those mounts are 2 pieces of square plate, maybe 10"X 8" or something and they did not move at all, the bottom step moved however......right off of the entire assembly [:D]
  7. kmh1596
    5,362
    Aug 20, 2007
    Western MA
    All good points.. I did not think about the mounting dimensions being different.
    Pics of this mod, or I'll put it out there that it didn't happen. [8D]
  8. Clive
    Clive New Member
    281
    Feb 18, 2013
    Better it wrecked the step than the side of the pup!
  9. Heady
    Heady Active Member
    1,581
    Sep 24, 2012
    Don't worry....most of us have one of these stories!
  10. yetavon
    3,435
    239
    Mar 11, 2010
    Western NC
    Didn't even think about it but I may have a set.....
  11. Darn
    Darn Pup to Hybrid
    699
    Apr 5, 2013
    I almost unplugged my camper the hard way, but my neighbors alerted me before I reached the end of the extension cord [HY] [PUT] [:O]
  12. yetavon
    3,435
    239
    Mar 11, 2010
    Western NC
    I take it back....there already gone....
  13. RockyRoo
    6,625
    253
    Jun 8, 2012
    I agree, pics or it didn't happen! I almost modded the side of the Roo today with a tree.
  14. vagov
    vagov Well-Known Member Gold Supporting Member
    4,695
    778
    Aug 13, 2012
    Pittsburgh, Pa
    sorry to hear about your step mishap, at least it was only the steps
  15. nfisherman
    nfisherman Member
    320
    Apr 23, 2005
    Illinois
    I snagged my PUP step once. It was still bolted on but bent toward the rear. 10 minutes with a sledgehammer and you can't tell that anything happened. ;-)
  16. vagov
    4,695
    778
    Aug 13, 2012
    Pittsburgh, Pa
    when I picked up the new tt at the dealer this weekend, I took the rig out for a test ride to test the brake controller adjustment when I noticed the step being out in the right side mirror, luckily I saw it before I left the parking lot, boy would that have sucked, damaged before I even got it home
  17. Snow
    11,363
    2,004
    Steps are the very last "step" in my hitching up to go or unhitching in storage .. last thing done each time, right after locking the door ...
