Radio comes on
Discussion in 'A-Frame PopUps' started by Crafty1, Mar 22, 2018.
  1. Crafty1
    Crafty1 New Member
    17
    Jul 6, 2016
    Calera, Alabama
    Anyone else have a problem with the radio constantly coming on and running the battery down? I tempted to take it out completely.
  2. BelchFire
    1,680
    401
    Mar 29, 2012
    SE Georgia
    I don't even have a radio, so I can't add any practical advice, but in a basic sense, can you determine why it's coming on randomly? Is it located in a vulnerable place where you or someone else is brushing up against it and inadvertently turning it on? Can you add a cutoff switch that interrupts the power so it doesn't come of for any reason, until you want it on?
  3. ny_rocking_chairs
    ny_rocking_chairs Active Member
    266
    42
    Jul 17, 2016
    Webster, NY
    Ours comes on when traveling depending what we have loaded there (usually a rubbermaid tote) which shifts into the power button (I assume). Ours came with a removable face plate so now we just leave the face off of it when traveling. Conveniently (sarcasm) ours is located in the cabinet next to the door, which puts it about a foot off the floor and where anyone can brush up against it walking in/out of the camper.
  4. nhlakes
    nhlakes Well-Known Member
    643
    317
    Oct 15, 2011
    DE and NH
    If it is coming on while the camper is in storage, you should disconnect the battery to avoid all a parasitic (and paranormal :eek:) drain. If it is coming on while you are using the camper either replace it (if you don't like the radio) or install a power switch to it as stated above.
  5. Customer
    Customer Well-Known Member
    2,436
    243
    Jun 5, 2014
    Well, I have no idea what radio you have or are referring to, but, it may have an alarm function. If so, turn the alarm off.
  6. Raycfe
    15,235
    1,449
    Disconnecting the battery is the way to go.
  7. nineoaks2004
    7,304
    3,039
    Dukes, Fl
    X 2 that is the way to be sure it stay's off
  8. Tukee44
    Tukee44 Member
    282
    Apr 28, 2012
    Do you know your phone come with a FM tuner? There is an apps for it. It requires an earphone to use as FM antenna. No internet connection is required.
  9. Snow
    10,134
    1,044
    Please elaborate. . When is the radio turning on?
  10. Cheesehead RV
    Cheesehead RV Member
    30
    Nov 4, 2017
    Sounds haunted to me.
    Better sell it for cheap and give me all the beer!
  11. McFlyfi
    McFlyfi Active Member
    420
    175
    Aug 1, 2014
    Thousand Oaks CA
    If your radio is like most, it's drawing nearly half an amp while it's off. The radio draws power to keep the clock running and any pre-sets stored.
    I put a switch on mine, so when it's off, it's off.
    With it switched, it can't "turn on" and it won't draw any power.
  12. jackquontee
    jackquontee Active Member
    301
    31
    Apr 24, 2013
    I have a 2016 Aliner Expedition and it seems anytime it's powered the radio comes on. I lifted the dinette seat above it and disconnected the power to it.
  13. BigTap
    BigTap Active Member
    143
    49
    Feb 22, 2018
    Worcester Area, MA
    If you want to keep pre sets put a rrlay and switch on the acc power wire typically red. If you want to kill power completely put the relay on the ground wire.
