Rail for outside stove top
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Braol, Oct 30, 2019.
  1. Braol
    Braol New Member
    22
    Oct 19, 2019
    Anyone here ever make anything to attach to this rail other than the stovetop?
    We have an 02 Coleman that didn't come with the outside stove but has the rail on the outside wall. I was thinking of making a table that one end would attach to the rail and have individually adjustable legs on the other end. We've taken it out twice so far. The first place we camped was fairly uneven, we had to stack wood of various thickness under our table legs to level it. The picnic table at the site was on the wrong side of the site to be convenient to use.
  2. bheff
    bheff Well-Known Member
    881
    414
    Feb 24, 2011
    NW Arkansas
    Several have made shelves.
  3. Aladin Sane
    1,059
    97
    Jul 3, 2008
    Iowa
    I made a table top that sits on the rack that normally would hold an rvque. I set my colman propane stove on it.
    FARfetched likes this.
  4. FARfetched
    FARfetched Active Member
    404
    167
    Nov 22, 2018
    Sector 706, Planet Georgia
    As I'm in the same boat, this is relevant to my interests! @Aladin Sane, what did you use on your table to clip onto the rail?
  5. Snow
    10,136
    1,047
    You can buy the rail assembly from any RV dealer or Amazon. .
  6. Aladin Sane
    1,059
    97
    Jul 3, 2008
    Iowa
    I had a bracket that holds an RVque. I just took the grill out and leave it at home. The bracket hooks in the track and has a frame that extends down the side of the camper about a foot.
  7. RetAF
    RetAF Member
    134
    Apr 22, 2010
    The exact same thing that I do.
  8. Econ
    Econ Active Member
    300
    109
    Aug 18, 2019
    Deep South
    ITs the hook concept. The rail attached to the wall is a "u" channel. Get a piece of oak or other hardwood that will fit the cross section of the "u". I used a hand plane to sneak up on a tight fit. Attach that to the shelf. Just to be safe a single support leg was attached to the bottom.
  9. Braol
    Braol New Member
    22
    Oct 19, 2019
    I wonder how much that rail can hold? I guess I'll see if I can tell what it's attached to in the wall.
  10. Econ
    Econ Active Member
    300
    109
    Aug 18, 2019
    Deep South
    2 small crock pots with no supports
    Let me edit this. There maybe a support in some peoples mind. The lip fits into the channel and holds the shelf tightly to the wall. The shelf is made with several Western Cedar boards/cut offs. Looks like I was cleaning out the cutoff bin. There are two "floor joists" about 2.5 to 3" wide that fit flush against the exterior wall when the shelf is at a 90 degree angle.
    The shelf has been decommsioned by the DW. It was only about a small crock pot wide. Not a table
    Braol likes this.
  11. MNTCamper
    MNTCamper Active Member
    889
    189
    Jun 14, 2014
    MN
    I still attach my stove exterior, but I added an additional rail and attach a table there with a single adjustable supporting leg outbound. It is quite study and the table can hold a lot. It is great when cooking and doing dishes outside. The table is a light weight composite panel and only weighs a few lbs. I go the let and the rail components on Amazon or maybe ebay. If you are going to put much weight on something attached to the slide, you should either have a support pole that goes to the side bracket or one that goes to the ground.
  12. Camper054
    Camper054 Active Member
    144
    60
    Jul 23, 2019
    Indiana
    This is what I was worried too...Instead of using the side rail, i just put a small table to put my stove and some other stuff that I need/keep handy. Yes, the ground is uneven and had to sort of level it using some wooden support underneath. Just sharing to give ideas. Picture from a recent trip. Mine is also 2002 Coleman!
  13. Braol
    Braol New Member
    22
    Oct 19, 2019
    This is what I came up with for this weekend. Slid a piece of 1/8 x 3/4 aluminum into the rail. Used a couple of angle brackets on the tabletop to hook over the aluminum strip. Made the legs out of 1/2 allthread and 3/4 tube so that I can adjust each leg individually.
    FARfetched, Camper054 and Econ like this.
  14. MNTCamper
    889
    189
    Jun 14, 2014
    MN
    If you are locked into the rail, you only need a single leg. Makes leveling much easier. They sell single folding legs with leveling capability.
  15. Braol
    Braol New Member
    22
    Oct 19, 2019
    I could not find any legs that had a fine adjustment.
