Re-skinning a pop-up
cowboiler
Oct 25, 2021
35
Oklahoma
I was at a hot air balloon festival last weekend and I saw these small travel trailers.
I loved the shiny aluminum skins and it got me wondering if anyone has ever tried to re-skin their popup with this material? The spec sheet for the camper says it .040 aluminum. There are no screws, so I'm guessing it must be glued to a plywood frame. Anyway, I really like the look and thought it would be a neat upgrade to the exterior of my 2008 Jayco 806. What do you all think? Would it be a big undertaking or worthwhile?
My Jayco 806.
jmkay1
2004 Fleetwood/Coleman Utah
7,728
I’ve seen many people repaint their campers, but not many reskin an existing camper. Just the sound of it sounds like a huge task, but I wouldn’t know all involved. Also not sure if you have solid plywood inside your walls. On my popup there is Only wood bracing some foam in some parts and the skin.
geoffm3
204
My Jayco 806.
All I can say is, get off your wallet. I tried to find some "stucco embossed" aluminum coil to match what came on the camper originally for ours and was quoted $1300 not including freight. I suppose if you can find a local place that uses aluminum coil sheet from a local supplier or a business that will sell to the public you might be able to get out a lot cheaper.
KeizerTrailer
142
Keizer, OR
Nice Jayco! We are in the process of getting ours cleaned up and ready for paint(will be next spring). Removal of the old, tired pinstriping and logos along with a fresh coat of paint can go a long ways. We are planning on installing new logos, but leaving the pinstriping off. All said and done will cost us $200.
cowboiler
Oct 25, 2021
35
Oklahoma
We have contemplated that, too. You will have to post a picture when you're finished. I would love to do a different color on ours, but our vinyl is blue and white so I still want it to match when it's popped up.
cowboiler
Oct 25, 2021
35
Oklahoma
I did find a place that sells the shiny .040 aluminum nearby (about 1.5 hours away). I was surprised it's only $130 for a 4'x10' sheet. I'm sure shipping would be expensive, but I didn't think the price of aluminum was bad.
Bowman3d
1,017
LaLa land (SoCal)
You could always just laminate over your existing skin. I've thought about having mine wrapped. Maybe you could find someone to wrap yours to get the shiny aluminum look.
bluespruce
128
A second vote for considering vinyl wrap if the surface is smooth. Not sure it would work well on a pebble surface.
im building a camper right now and in the process of vinyl wrapping. Pretty easy on flat surfaces with the right technique. Lots of color and effect options. Probably under a couple hundred bucks for the vinyl For a small trailer.
cowboiler
Oct 25, 2021
35
Oklahoma
I would like to see how a wrap turned out if anyone has tried it. Ours is that pebble surface, so I'm not sure how it would go. Our cut vinyl decal looks good on the pebble surface so it might work!
Latest posts
