Recaulking camper
Discussion in 'First Time & New Camper Owners' started by Mtlangst, Jun 16, 2019.
  1. Mtlangst
    Mtlangst Member
    88
    Jun 14, 2019
    i ordered a 4 pack of Dicor 501LSW-1 Self-Leveling Lap Sealant i am assuming this is good caulk to use. About how many tubes does it take to recaulk a camper? Do you replace all seams everywhere or just the roof?
  2. GreyFox
    GreyFox Well-Known Member
    1,407
    662
    Oct 10, 2018
    S Ontario
    Self leveling lap sealant should only be used on horizontal surface as it will sag on vertical surfaces - for those you want a lap sealant such as non sag Proflex. If this is a popup you're talking about you certainly don't need 4 tubes, heck you're likely to use just a small part of one tube for the roof.
  3. joet
    4,706
    926
    Dicor also makes a nonsag. X TRM would have been a better choice as it will bond to any surface. But at any rate make sure you have cleaned the areas to be sealed good. We use brake kleen on a rag.
  4. Mtlangst
    Mtlangst Member
    88
    Jun 14, 2019
    Do you use that one caulk for all over your camper?
  5. joet
    4,706
    926
    We use the self leveling for the roof and nonsag for sides. We also use Pro Flex around windows and doors
  6. roybraddy
    roybraddy Well-Known Member
    2,186
    760
    Mar 23, 2016
    King George, Virginia
    I certainly wish I had used the DICOR over SILCONE seal for my 2008 StarCraft RT14 roof.
    Google image
    It looked like the oem seal was silicone so that is what I used to reseal the side metal trim and the roof on both sides here... The SUN UV's quickly eat up the silicone repair and allowed run off water get inside my trailer rear corner like shown here...
    The outside of the corner has no damage but the inside particle board is all but eat up... The rear corner BUTYL STRIP actually became separated from the Diamond Plate rear side.
    This was sitting in my drive-way for a couple of season where the roof run off was going to this side shown... Had no idea it was doing damage haha... I also should have put a tarp over the roof as well just sitting in the high sun for a couple of seasons unattended...
    Live and learn haha...
    Roy Ken
  7. Pnut
    Pnut Member
    76
    34
    Jul 8, 2018
    NE Georgia
    I just did mine and I used the dicor self leveling on the roof and dicor no-sag on the sides. I used acetone to wipe the surfaces before I re-caulked. That is what the Dicor site recommended. Be careful not to make a mess or get it on your hands because that stuff does not clean up easily.
  8. Mtlangst
    Mtlangst Member
    88
    Jun 14, 2019
    Did you smooth the caulk out or leave it as a bead? I have read where you aren’t supposed to smooth it out with your finger.
  9. Orchid
    Orchid Sharp Shootin' Grandma
    5,335
    2,035
    May 8, 2011
    Florida by way of WV and MD
    Does it bond to silicone?
  10. GreyFox
    1,407
    662
    Oct 10, 2018
    S Ontario
    NOTHING bonds to silicone, not even more silicone. [XX(]
    Byrd_Huntr likes this.
  11. Orchid
    5,335
    2,035
    May 8, 2011
    UGH! We have a huge RV that needs caulking before being sold. Of course the PO used silicone.
  12. Pnut
    Pnut Member
    76
    34
    Jul 8, 2018
    NE Georgia
    On the roof I just left it as a bead, but the sides I smoothed it out some but I tried to leave a thick layer.
  13. Mtlangst
    Mtlangst Member
    88
    Jun 14, 2019
    I am in the process of removing the old caulk. Do i need to remove it completely or is it good the way it is shown in the picture a d go over this with new caulk after cleaning with acetone?
  14. Pnut
    Pnut Member
    76
    34
    Jul 8, 2018
    NE Georgia
    I would try to remove all you can but it looks pretty good. When I redid mine I went out past the old caulk with the new to make sure I got a good seal.
