Recommendation for generator for 11000kbtu AC?
Discussion in 'Boondocking' started by JasonR, May 24, 2020.
  1. JasonR
    JasonR New Member
    May 24, 2020
    Ha, sorry, just saw you provided a hyperlink. Thanks again!
  2. Eskimorob
    Eskimorob PUP life Gold Supporting Member
    112
    57
    Jul 5, 2016
    Disclaimer...I have not actually run my Jayco ac for an extended period of time on generator power but I did confirm the ac started and ran on a moderately hot day (80f) with a Honda 2000i companion and a Honda 2200i in parallel.
    You will need 2 of those gens in parallel to safely start and run your ac. You may find your gens showing temporary overload as the ac starts up. My Honda 2200 is rated at 18 amps output at full power x2 means the gens can handle about 36amps. Running the ac isn’t the issue it’s starting the ac that is the problem.
    You will see posts on the web saying that a single unit will start and run the ac, but I felt that was going to hurt the genset or the ac in the long run which is why I have two. You can opt for a single 5k unit but the size/noise becomes a problem with something that big. I felt that 2 of the Honda portables fit better for my use, and works better in the event of a power failure at home having multiple fridges and freezers in different locations in the house.
    There are a couple of tricks to get by the startup draw like turning the ac fan on first before setting the temp down to kick in the compressor. You could also look at one of these things to make life easier on your gen(s). Keep in mind, installing one of these will probably void your ac warranty.
    https://www.amazon.com/Micro-Air-EasyStart-Soft-Starter-ASY-364-X20-IP/dp/B085468Y9P/ref=asc_df_B085468Y9P/?tag=hyprod-20&linkCode=df0&hvadid=416796348214&hvpos=&hvnetw=g&hvrand=14279290980204694059&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009997&hvtargid=pla-887737024978&psc=1&tag=&ref=&adgrpid=93124985239&hvpone=&hvptwo=&hvadid=416796348214&hvpos=&hvnetw=g&hvrand=14279290980204694059&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009997&hvtargid=pla-887737024978
  3. JasonR
    JasonR New Member
    May 24, 2020
    Thx; here is an update for anyone who cares; the 2200EU runs the AC fine at sea level and up to about 3500’. It’s not running it in CO at around 6500’. I’ve installed a new jet for altitude and will see if that helps; next step would be microstart
  4. Lisa Moomaw
    Lisa Moomaw New Member
    Jul 27, 2020
    Denver, CO
    Hi Jason, what part of Colorado do you camp in? My hubs and I do Jefferson and Buffalo Creek.
  5. JasonR
    JasonR New Member
    May 24, 2020
    We live in castle rock and try a little of everything. Rampart is 30 minutes away and is a great quick getaway with the dirt bikes. Buena vista, steamboat, crested butte, and down around telluride are some of our favorites.
  6. JasonR
    JasonR New Member
    May 24, 2020
    Update on the AC and generator. I installed the micro easy start and it works like a champ. My Honda 2200 has no issue with the dometic penguin Low profile 11k btu. I recently tested it at 8500 feet.
    Chip Monk likes this.
  7. GreyFox
    GreyFox Well-Known Member
    2,447
    1,279
    Oct 10, 2018
    S Ontario
    Great testimonial that others who've also matched a Honda EU2200i to a roof mount A/C wired with a Micro-Air Easy Start would agree with! [:P] Congrats! [:D]
