Redoing my cabinets I need advice
Discussion in 'General Camping Discussion Forum' started by Buckeyechris, Feb 2, 2017.
  1. Buckeyechris
    Buckeyechris Member
    31
    Jan 27, 2017
    IM getting ready to redo all of my cabinets and counters. The laminate is peeling on some of the cabinet doors. Any advise on handling this
  2. Wecamp04
    Wecamp04 Member
    161
    Sep 14, 2014
    TN
    I would try contact cement
  3. frankvanw1
    frankvanw1 London, Ontario, Canada
    360
    Mar 18, 2009
    London, Ontario
    Buckeye,
    What do you mean by 'redo'?
    If you are going to paint them that can be done. See the forum for hints.
    Are you going to replace them or some of them? Replace hardware?
    Need some more info to help here bud.
    Thanks and happy camping.
  4. Lumbergodd
    Lumbergodd Member
    90
    52
    May 20, 2016
    My old counter tops were looking pretty bad. The particle board substrate had gotten wet and swelled up and the laminate itself was coming unglued. I rebuilt the tops using 1/2" exterior grade plywood for the substrate and a high-pressure laminate for the surface. I used 1x2 oak to edge the sides and front and stained it to match the rest of the cabinets. The mistake that I made was in using the 1x2 oak for the sides of the folding cabinet top. It is now too big to fold into place. I have to lift it up and place it into the storage position. Not a real big problem but something I would take into account if I ever did it again. I also eliminated the sink, as we never used it and it gave us more usable counter space in our 8' pup. I tried to attach pics but their file size seems to be too big.
  5. Buckeyechris
    Buckeyechris Member
    31
    Jan 27, 2017
    I'm completely replacing every counter top. I'm gonna prime and paint all the cabinets. Replace all hardware. I'm also gonna lay some peel and stick flooring down. I sanded all the peeling laminate off the front of cabinets. Prob take 3 coats of primer to cover all the old laminate. But it will be worth it. Was thinking of using mdf for counters?
  6. aschumann
    aschumann Get OUTSIDE!!
    132
    18
    May 28, 2014
    Are you going to paint of cover the MDF on the counters.... If you laminate the MDF it will be great but it you are just painting it, I would put several coats of paint to seal the MDF. MDF can act like a sponge with moisture on it even after its lightly painted.
  7. Buckeyechris
    Buckeyechris Member
    31
    Jan 27, 2017
    Was gonna paint them. I like the laminate idea. What laminate would u recommend?
  8. aschumann
    132
    18
    May 28, 2014
    Any laminate would do and be a better countertop surface. Check Home Depot sometimes that have sheet laminate that you can buy. I believe they buy from Wilsonart.
    I don't know how technical or handy you are with tools but it is not too hard to laminate countertops especially if you are making new ones to be installed.
  9. Lumbergodd
    Lumbergodd Member
    90
    52
    May 20, 2016
    I would stay away from the MDF because of 1, weight, and 2, susceptibility to moisture. For as small as the counter tops are and as little use as they'll get, ACX or BCX plywood should be sufficient. My original counter tops were made with MDF and that's why they swelled when they got wet. I'm sure that material was used by the factory as a cost-savings measure.
  10. Buckeyechris
    Buckeyechris Member
    31
    Jan 27, 2017
    What about the edges. ?
  11. michaeltdyer
    michaeltdyer Member
    164
    22
    Nov 26, 2012
    Denver Colorado
    I bought a piece of laminated kitchen countertop at a household surplus store (like the Habitat for Humanity resale stores) and cut that to fit to replace my old counter top. It came out great!
  12. aschumann
    132
    18
    May 28, 2014
    There are a few ways to treat the edges. Let's say you bought some material that already has laminate on it then you can edge it with a iron on edging that can be bought at Lowe's. [​IMG]
    This is the cheapest most durable method.
    Now if you decide to buy a sheet of laminate and do it yourself then I would cut strips of the laminate and edge the counters first then laminate the top. Getting into doing this will require a hand router and a file and some craftsmanship on your part. But you will end up with a good and durable countertop.
