REf Problems need help
Discussion in 'Refrigerators and Coolers' started by mark.sibole, Jun 25, 2013.
  1. mark.sibole
    mark.sibole New Member
    28
    May 12, 2013
    Hello All.I have a flagstaff pup with I believe a 2.0 cubic foot fridge in it.
    The small ones they add in a pup.It cools fine on AC and Coold fine on DC but on gas it will not cool.It lights has a flame but no cooling.Any Tips or suggestions.Cant find a model number on it so im stuck here.
    Its a Norcold
    Thanks in advanced
    Mark
  2. lbcarr87
    lbcarr87 New Member
    853
    Aug 29, 2009
    Is the pilot light blue or sort of an orange yellow color. Blue is better and means the gas is working efficiently. It may just need a good cleaning.
  3. mark.sibole
    28
    May 12, 2013
    Pilot light is a nice blue .and seems to be heating well.I may have to remove it all and give it a good cleaning as it hasnt been used in at least 5 years.Bought it used and re conditioned it
  4. Raycfe
    15,235
    1,449
    Maybe a better baffle between the upper and lower compartments would be a first step. The heat from the flame maybe just floating around both compartments and need to be controlled. Thats why we do Refrigerator Fan Mods.
  5. speckhunter80
    4,782
    62
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Is there a separate temp control for the gas. Maybe you just don't have it turned to cold.
  6. mark.sibole
    28
    May 12, 2013
    Yes there is a temp control for gas and it is turned on high.As soon as this heat settles dowm ill pull the shop vac and compressor out and blow it all out and remove both vent vovers and see if I can find any Blockages.
    Ill also check out the mod thanks for the tips.Been way to many years since ive played with one of these.
    BUt At least we had a good trip out to the lake for a long weekend.
  7. mark.sibole
    28
    May 12, 2013
    Just spoke with the original owner.The Ref hasnt been fired up in 10 years so im thinking a major cleaning and removal of all illegal Immigrants from the system is in order.
    Its 91 degrees out sao dont think its happening today.
    Hope you all have a great camping season and stay safe.
    Eventually Ipp post some pics of my trip to the lake this summer.
    I have a nice spot on Lake Margerth right next to the beach.
    Easy to keep an eye on the kids and they claim i only go there to watch the Bikinis lol.
    STAY SAFE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  8. mark.sibole
    28
    May 12, 2013
    Blew it all out with the compressor then ran the shop vac on it.Used a needle and cleaned the burner openings.It now cools to 28 degrees on gas.
  9. daveo1289
    daveo1289 Active Member
    974
    81
    Apr 24, 2012
    Rochester NY
    Great!! Glad to see the problem got fixed.
