Refilling small propane bottles
Discussion in 'Propane - Got Gas' started by grantar2, Dec 19, 2013.
  1. chiefbowes
    chiefbowes Member
    189
    Apr 24, 2008
    Right or Wrong i refill my cylinders. I have been doing this for over 20 year. I put the little cylinders in the freezer to increase the volume they will take. If you dont you may only get 9 or 10 ounces in. I also store them with metal threaded caps which seal any possible leakage. Empty or full they have caps on them. I switch to a propane tree 2 years ago so i dont use very many any more. I keep 2 in the pop just in case. Gary
  2. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    Well said!
  3. ChocoChock01
    4,020
    Mar 7, 2012
    Probability vs. Cost benefit incl. effort to refill.
    I my case, I didn't realize the valve issue was an issue, but did wonder why they won't maintain their fill wt. after re-filling.
  4. rabird
    6,714
    306
    TX
    size matters [LOL]
    the bigger the container the farther it needs to be away from me [;)]
  5. JungleJim
    JungleJim New Member
    990
    Feb 25, 2008
    Those are cool!!!!
    I think the disposable ones should be outlawed....Just doesn't make sense to spend so much material and energy (production) for something that contains so little propane.
    I'm going to try to find these.
  6. grantar2
    grantar2 Member
    227
    Nov 4, 2013
    Mission Viejo
    I agree with that. I have seen the results of a 20# propane tank blowing up (on the back of a sailboat). The damage destroyed the boat it was on and damages half a dozen others. I have had the bottom of one blow out on me, freezing my tennis shoes to the ground and creating an instant sheet of ice. (was about 90% full when it failed).
    Still, glad my PUP has one.
  7. rabird
    6,714
    306
    TX
    Be sure and get the special refill hose/valve and a fork lift (liquid delivery) cylinder so you can refill em, and what ever training that is required. or use the mac adapter [:D]
    Will we ever see these in exchange bins when we are forced to mow and weedeat with propane?
    me too and glad I have disposables bottles when needed for the lantern, tiki torch, buddy heater in deer blind and ...
  8. skiball
    skiball New Member
    1,295
    Oct 29, 2013
    I'll just refil the disopsable ones. I have wondered about the metal caps (weather or not they work) and as someone mentioned above. They do. 4 caps, 4 refilled bottles, I'm set.
  9. ChocoChock01
    4,020
    Mar 7, 2012
  10. brianbigdogsmith
    brianbigdogsmith Camp more Camp more often
    822
    Feb 20, 2012
    Melviindale MI.
    I picked up my small can filler up at harbor freight
  11. skiball
    skiball New Member
    1,295
    Oct 29, 2013
    The tankes in that video are very large. Probably O2 or something like that not propane tanks.
  12. ChocoChock01
    4,020
    Mar 7, 2012
    I just enjoy watching Russian drivers! [LOL]
  13. Yak
    Yak Well-Known Member
    1,204
    86
    Apr 18, 2009
    O2 wont burn
  14. CamL48
    CamL48 New Member
    1,420
    Feb 20, 2012
    Correct. O2 is not flammable. Cracks me up when people think otherwise. I always tell them to try writing a combustion equation around O2 and let me know how that works out.
  15. Tribble
    Tribble New Member
    304
    May 17, 2013
    Tank explosions/fires are typically referred to as a BLEV (pronounced BLEH-Vee)
    This means Boiling Liquid Expanding Vapor.
    Heat causes the liquid to evaporate into a gas, as more and more gas builds the internal pressure of the tank increases. Eventually the tank ruptures and the gas escapes.
    Can pure oxygen "Burn", no, but neither can any other pure element.
    Oxygen is the catalyst of "Burning". In fact many of the most powerful earthly reactions use pure oxygen such as those that power spaceflight.
    Oxidizers are chemicals with free oxygen as part of their chemical make-up. For example Nitrous Oxide, which is used to increase the amount of oxygen available in the combustion of gasoline for internal combustion engines.
    Oxygen itself is Highly reactive when in contact with other materials. Hydrogen, Carbon, etc will readily react in the presence of it. You may have heard of the results of these reactions....
    H2O, Yes, Water is the ashes of Hydrogen burning in the presence of Oxygen.
  16. oeagleo
    oeagleo Caching, and Photography!
    132
    Dec 20, 2009
    Salt Lake City, Utah
  17. dave123
    dave123 freedom is not just another word
    134
    Mar 29, 2013
    keep us informed ok oeagleo?
    sending this to myself for future reference,
  18. skiball
    skiball New Member
    1,295
    Oct 29, 2013
    The one I ordered from eBay just came in the mail today along with 2 packs of brass caps. Can't wait to use it.
  19. CamL48
    CamL48 New Member
    1,420
    Feb 20, 2012
    Wow! Really?! The portal is a great place to learn about PUPs, but not so much about chemistry. [V]
    There are several elements that are flammable and around which you can write a combustion equation. Combustion is the combination of a substance with oxygen that releases heat and, usually, light.
    2H2 + O2 -> 2H2O
    C + O2 -> CO2
    2C + O2 -> 2CO
    2Na + O2 -> Na2O2
    Magnesium, potassium, phosphorous, sulphur, etc. These are all "pure elements" around which a combustion equation can be written.
    However, oxygen doesn't burn. There is no combustion equation for oxygen. This is only relevant because a person above opined that the highly flammable tank might be oxygen. Nope.
  20. Tribble
    Tribble New Member
    304
    May 17, 2013
    I was speaking in terms of a single element. Not a combination of the elements. Although I suppose fission or fusion could count.
    Sent from my Nexus 7 using Tapatalk
