Reflectix for dummies
Discussion in 'Cold Weather Camping' started by kimberline18, Sep 16, 2011.
  1. scorp28
    scorp28 Member
    179
    Aug 9, 2009
    Elmwood, IL
    Thanks. That was confusing me a bit. I didn't think to check their website. I think I am going to go with this.
  2. tjcamp
    tjcamp New Member
    318
    Sep 22, 2011
    Has anyone tried using those popup gizmos, the high wind ones (with the bungee cord) and then rigged some reflectix under the bunk (outside liner, like) so it covers the underside of bunk end, leaving a flap against the ends of the camper? Does anyone understand? I'm trying to describe an image I have in my head, lol, not sure if I'm writing it correctly.
  3. bflentje
    bflentje Member
    296
    Aug 24, 2009
    How about Reflectix attached to the underside of the bunkends? Effective? Would it have the same moisture issues as sealing under your floor boards?
  4. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    Yes, it would cause the same problems. Moisture can't get through it so it would be trapped between the Reflectix and the wood. Not good.
  5. bflentje
    bflentje Member
    296
    Aug 24, 2009
    Removable with velcro and only have it attached when bunks are deployed? I assume it's a long term issue in regards to moisture in that location.
  6. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    You could try it and then when you take it off you will find out how much moisture is there.
    But from a completely practical point of view, why spend the money on the Reflectix for that application when you can spend a lot less on some Styrofoam board to slide under the mattress on the inside?
  7. bflentje
    bflentje Member
    296
    Aug 24, 2009
    I wasn't clear, I've already done the foam. I wanted to do both.
  8. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    My recommendation is to forget about the idea.
  9. kb2qqm
    kb2qqm New Member
    Mar 7, 2013
    Www.atticfoil.com
    Works great too. Indestructible.
    TinaS likes this.
  10. Sharkdude
    Sharkdude New Member
    17
    Mar 14, 2018
    foam mats cut to size under your mattress ?
    KamperKel likes this.
