Refrigerator doesn't work?
Discussion in 'Refrigerators and Coolers' started by Sarah Marx, May 9, 2020.
  1. Sarah Marx
    Sarah Marx New Member
    May 2, 2020
    I just bought a 1996 jayco udk used but the refrigerator isn't running. There isn't anywhere inside or on the front to switch it on and after several hours of the power being plugged in it isn't turning on. Does it run off gas? Am i missing something?
  2. bheff
    bheff Well-Known Member
    1,504
    928
    Feb 24, 2011
    NW Arkansas
    Generally they are more efficient on propane. There should be a control panel on the outside of the pup. (Behind the fridge)
    Some take better part of 24 hours to cool down.
    Sarah Marx likes this.
  3. Raycfe
    17,433
    2,994
    All the controls are on the outside of the camper. The only thing inside maybe the make and model number of the unit. Post that and we can tell you how it operates.
    Open the large lower grille on the outside. May have a twist tab or 2 black clips that you turn 90 degrees with a screwdriver.
    Screen Shot 2020-05-09 at 8.10.07 PM.png The grille on the left is the refrigerator. The smaller grille above is its exhaust grille. The grill over the tire is the water heater.
    xxxapache likes this.
  4. WVhillbilly
    WVhillbilly Well-Known Member
    841
    638
    Jun 6, 2018
    WV
    It probably runs off propane too, but as others have said you turn it on outside of the camper.
    There will be controls for 12V 110V and propane. Depending on if it's a 2 way or 3 way fridge.
  5. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    Fyi, this type of fridge does not make any noise when it runs. A tiny heat source smaller than a candle flame when running on propane is the driving force for the cooling system.
  6. McFlyfi
    McFlyfi Well-Known Member
    687
    393
    Aug 1, 2014
    Thousand Oaks CA
    After you turn it on, wait an hour or so and touch the silver cooling fins inside the fridge. If the are cold, it's working.
    bheff likes this.
