refrigerator not staying lit
Discussion in 'Refrigerators and Coolers' started by rideon, Aug 24, 2008.
  1. rideon
    rideon Member
    116
    Jun 22, 2008
    When I switch my frige to gas, it want stay lit over 5 minutes. What could be the problem?
    Thanks.
    2001 Coleman Bayside
    2002 Toyota Tacoma 4x4
    2002 Toyota 4-Runner
  2. dupreet
    dupreet New Member
    2,184
    Jul 5, 2007
    High Point, North Carolina
    Hey,
    First off, you may want to check your gas supply with a stove burner - watch it for a few minutes and see if there are major variations in flame height/color that might indicate a pressure problem, or maybe a bad tank????
    One 'mechanical' issue that may be the cause of the fridge problem is the thermocouple on it. This device keeps the gas flowing as long as the burner remains hot - this is why you have to hold down the control button for 30-45 seconds after you light the fridge to allow the burner to warm and the thermocouple to open up. If it is malfunctioning, it can erroneously shut off the gas even though the burner is burning.
    Knock on wood, I have had little/no problems with any of my camper fridges over the years.
    Todd
    Wife, 3 Kids, 4 Dogs, 3 Cats, The Wabbit
    '88 Palomino TXL hardsider
    '93 Ford E-350 Van
  3. rideon
    rideon Member
    116
    Jun 22, 2008
    Thanks, I'll try that.
  4. KISMETT
    KISMETT New Member
    17
    Jun 27, 2008
    Another thing to check - make sure the fire box at the base of the chimney is clear of all debris. Rust has a habit of building up there as well as pine needles etc. If you have access to a compressor, just stand aside & blow the area out. This area requires good air flow in order to keep the flame lit.
