Refrigerator shroud
Discussion in 'Miscellaneous Repairs & Maintenance' started by Robmoo, Nov 4, 2019.
  1. Robmoo
    Robmoo Member
    36
    Aug 12, 2017
    My Dometic RM4223 has fins for condensing the ammonia vapor. These fins have nothing to direct air through them. I was thinking about taking some flashing and fashioning a shroud that would direct airflow through the fins. I could take some flashing and perhaps even cut out a hole for the 110v/12v controls so that I do not have to remove the shroud to access these controls.
    Has anyone tried this? Any thoughts?
  2. GreyFox
    GreyFox Well-Known Member
    1,552
    763
    Oct 10, 2018
    S Ontario
    I prefer using Reflectix which can be bent and fashioned into pretty well any shape you want, is far easier to work with than flashing.
    nineoaks2004 likes this.
