removable Dometic boiler shield in popup
Discussion in 'Refrigerators and Coolers' started by Anthony Hitchings, May 26, 2019.
  1. Anthony Hitchings
    1,076
    483
    Mar 2, 2019
    existing boiler flame shield has a little window to view flame - but you can NOT see the flame, not possible at all (no Effin way!) , so I modified it to be totally removable without tools. Thumbscrew screws into a Tee-nut installed from the underside. I cut away the tab for the anchor screw and relocated it to use with the Tee nut (1/4"-20 tpi). A Dremel was most helpful, as was a pop rivet tool.
    xvz12 and Sjm9911 like this.
  2. Sjm9911
    6,538
    3,908
    Looks like an old school flame veiwer now, that they had on all the old oil fired furnaces!
