Removable stabilizer jacks
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Raycfe, Nov 21, 2021.
  1. Raycfe
    17,809
    3,289
    I just watched a YouTube about a guy in Canada making his own camper. One thing he did was make a channel for the stabilizer jack to side in. Seams like a good idea. I have torn off one of my rear jacks twice.
    And here is something else to think about .......... If the dump valve was closer to the tank (on the inside of the frame) an adapter for the hose could be made. The gray water tank valves are usually closer to the tire so clearance isn't a problem but the hose would have to moved to the gray tank valve for drain and flushing ........
    I control my black tank valve with a rod to the rear bumper so moving that would not be a problem ....... but I would just have to struggle putting the hose on and off.
    Just thinking out loud.
    Have to protect my low hanging fruit.
  2. PopUpSteve
    PopUpSteve Administrator
    20,118
    3,099
    Dec 22, 2002
    Southeastern PA
    Got a link to that video?
  3. gladecreekwy
    1,559
    2,403
    Sep 25, 2016
    Jackson Wyoming
    Axel flip to gain more clearance?
  4. Raycfe
    17,809
    3,289
    I don't agree with everything he is doing ......... interesting
  5. Raycfe
    17,809
    3,289
    My trailer have side frame mounted torque flex rubber axles ....no springs and the front and rear sections of the frame bolt to the axle flanges. .dumb idea if you ask me
  6. xxxapache
    4,117
    2,426
    I used to set up a trailer that had a side wind pipe mount jack mounted on each corner. They had plenty of ground clearance when turned sideways.
    gladecreekwy likes this.
  7. PopUpSteve
    20,118
    3,099
    Dec 22, 2002
    Southeastern PA
    That is exactly how I built my camper!
  8. Raycfe
    17,809
    3,289
    what do you think about the jack mounts?
  9. gladecreekwy
    1,559
    2,403
    Sep 25, 2016
    Jackson Wyoming
    So no lift possible. Can you move up a tire size ?
  10. PopUpSteve
    20,118
    3,099
    Dec 22, 2002
    Southeastern PA
    Nice but I can see them getting left behind at a campground.
    Raycfe likes this.
  11. popup-flyer
    popup-flyer Active Member
    255
    182
    May 11, 2021
    Central Texas
  12. PopUpSteve
    20,118
    3,099
    Dec 22, 2002
    Southeastern PA
    @popup-flyer yup, that's basically the same thing as what the guy in the video was using.
  13. popup-flyer
    255
    182
    May 11, 2021
    Central Texas
    In hind-site making them like that would have been considerably cheaper :D
  14. Raycfe
    17,809
    3,289
    $100.00 for 2 wow ........... there is a set on EBay now for 75. Saveajack
    How about this idea ............ Install mounting bolts hanging down from frame and lock in place with a jam (thin nut) and with a hole drilled in the ends hanging down ...... install the jack ...... insert hairpin clip, etc in the hole (to hold jack in place) ........crank up jack .......
