Removing canvas from 1998 Starcraft Spacemaker
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by barrientosbunch, Dec 1, 2019.
  1. barrientosbunch
    barrientosbunch Member
    40
    Feb 23, 2019
    79459955_2766971263323315_8285546274002829312_n.jpg 79089826_2766971069990001_6271271878501859328_n.jpg 78629006_2766971193323322_1040564528783294464_n.jpg
    How do I remove this canvas for the dinette slide? Photos attached for the left side (inside looking out). There is velcro along the side, what goes in that area? There is NO velcro on the right side of the dining slide canvas. Same issue with the cord running through a sewn channel.
  2. davekro
    davekro Active Member
    614
    198
    Aug 30, 2019
    SF Bay Area, CA
    Why wouldn’t you just open the blue wire connectors and pry each wire out? Then you can slide the wire out thru the vertical ‘tunnel’ in the canvas. When replacing, just place the wires back in the blue squeeze connector and re-squeeze the wire end in, then snap the side of the connector to relocate it. Easy-peasy.
    bheff likes this.
