Removing multiple coats of paint...
Discussion in 'Camper Restoration Projects' started by rb_weaver, Oct 21, 2019.
  1. rb_weaver
    rb_weaver New Member
    May 20, 2014
    I have a late 70's model Jacyco Cardinal that I love, but previous owner(s) have painted it so that it now has at least 2 coats of paint over the original. The outermost coat is pealing off in 2-3 inch flakes and the thing just looks awful.
    My question is, what would be a good method for removing the paint?
    Should I get it down to the bare aluminum skin before repainting?
    I really don't know how to go about tackling this. Any advice would be greatly appreciated.
    Note: I would be doing this myself out in the driveway.
  2. WrkrBee
    WrkrBee Well-Known Member
    2,441
    934
    If the paint is thick enough, you may be able to use an oscillating tool with a scraper blade to get the majority of paint off. Aluminum skin is thin, so be careful. Even an orbital sander can remove metal quick. A chemical remover may be the safest.
  3. rb_weaver
    May 20, 2014
    Thanks! I'll try a chemical remover first and see how it goes.
  4. bheff
    bheff Well-Known Member
    829
    383
    Feb 24, 2011
    NW Arkansas
    Use "aircraft paint remover" found at Walmart and all auto part stores. Works amazingly well.
    Edit: dont buy the aerosol. Get the gell and brush it on.
    xxxapache likes this.
  5. xxxapache
    2,868
    860
    I would hit it with a pressure washer before breaking out a sander, oscillating tool or aircraft stripper.
    Aircraft stripper does work well, but it is a messy job.
    Ladiesman likes this.
