Removing Propane Tank and Battery for storage space....
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by kmeece, May 4, 2013.
  1. kmeece
    kmeece New Member
    136
    Apr 19, 2013
    We never use our propane gas (we cook with dutch oven) or the battery on our pup... so I was considering removing them (keep everything if we changed our minds) and using that space for a plastic storage trunk (action packer). I thought I would just wrap bungee cords around the frame to keep it in place. Has anyone done this before or have a better idea?
  2. speckhunter80
    4,782
    63
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    that would be the simplest way to go but you might consider a slightly more permanent solution of using two square axle "U" bolts with backing plates. If you come up from the bottom and lock the storage box then it would be more difficult for someone to steal it.
  3. Wrenchgear
    3,455
    710
    Aug 5, 2010
    5 Star Eagle Camper
    I agree, a couple of U bolts would work excellent. Good idea to hang onto everything for future use.
  4. Unstable_Tripod
    14,279
    40
    May 20, 2008
    Seattle, Washington
    Definitely hang on to the components and don't damage or remove the lines, fittings, etc. Without these things your camper will be worth less if you want to sell it.
  5. Raycfe
    17,006
    2,549
    X2 and cap the propane line to keep it clean.
  6. Twisty
    Twisty New Member
    4,375
    Aug 24, 2008
    Hillsboro, Oregon
    Does the pup have brakes?
    Do you need a battery to operate them in case of a breakaway?
  7. hotrodcamper
    hotrodcamper Member
    972
    Nov 3, 2012
    You could move battery to inside of pup. Mine is under a bench. If you need it for breakaway switch it's there. I don't use mine either,but am keeping space for it in case I want it in future.
  8. JungleJim
    JungleJim New Member
    990
    Feb 25, 2008
    We camp without them too.
    We ordered ours prepped for a battery (has holder, etc), but we've never installed one and get along fine.
    There are some nice aluminum boxes made to go in that space, if you want something more permanent.
  9. speckhunter80
    4,782
    63
    Jul 26, 2012
    I was gonna give the same answer you gave until I looked up the camper and it weighs less than 1500lbs so I don't it has brakes.
  10. arthuruscg
    arthuruscg Active Member
    1,363
    Nov 14, 2012
    I cant see way pop he has, but starting in 02 coleman put brakes on all the popups.
    He could get one of the mini batterys just for the brakes.
    Sent from my DROID4 using Tapatalk 2
  11. kmeece
    kmeece New Member
    136
    Apr 19, 2013
    Mine doesn't have breaks. It's a 2006 Fleetwood 206 LTD. Plus... when we purchased it the battery wasn't on the camper. The original owner removed it and installed a metal tool box or a small amount of storage. Since the battery was already removed, I thought we could take the tank off and have more storage.
  12. Ken Mc
    Ken Mc Member
    184
    Feb 19, 2013
    Sounds like a good idea. My used Viking had been modified in a few ways, but 1) propane tank and hoses had been removed and 2) battery had been removed. I had thought about just installing a storage box on the front as you described. But, I ended up buying new propane hoses, regulator, tie downs and reinstalled all that. And have a battery box and planning on getting that all fixed up. I usually do not use propane and battery but just trying to fix it back up somewhat origonal. Yes, just keep all of your hardware. I wish my previous owners would have.
    Good luck
  13. arthuruscg
    1,363
    Nov 14, 2012
    I am removing the tank from my Taos to make a place to put the bicycles.
