Repair a few holes in the roof
Discussion in 'Roof/Floor Repair & Maintenance' started by Kasey Redrum, Oct 26, 2019.
  1. Kasey Redrum
    Kasey Redrum Member
    32
    Oct 17, 2019
    2005 rockwood 1640 ltd, roof seems to be aluminum, and there are a few small holes, and a small crack. I am just looking to keep it from leaking. I am thinking silicone, but what type is made for that purpose? The roof has some texture to it. Thanks for any help.
  2. joet
    4,676
    915
    Instead of silicone you want to use Dicor or X TRM in a self leveling compound. After a period of time, silicone won't stick to the roof
  3. BikeNFish
    BikeNFish Well-Known Member
    2,858
    1,764
    Apr 24, 2017
    Maplewood, MN
    No silicone! Self leveling Dicor on the horizontal surfaces and non-sag for vertical surfaces.
  4. Kasey Redrum
    Kasey Redrum Member
    32
    Oct 17, 2019
    Great thanks. FOund Dicor for roof, $11 a tube on Amazon.
  5. Kasey Redrum
    Kasey Redrum Member
    32
    Oct 17, 2019
    Ok so the Dicor, for roof, self leveling. How does this get applied? Is it like normal caulk? A bead? Or is it going to flow out like a puddle?
  6. BikeNFish
    2,858
    1,764
    Apr 24, 2017
    Maplewood, MN
    Self leveling Dicor will not "flow out like a puddle", but it will "flow" slightly and it will remain mostly raised. On my roof seams, I just ran a bead. On my vent, I ran several beads. I put it on pretty thick mostly because I had an entire tube to use for just the vent and I didn't want to toss out too much of the remaining Dicor in the tube. Waste not, want not.
  7. Kasey Redrum
    Kasey Redrum Member
    32
    Oct 17, 2019
    Do you ever flatten it with finger?
  8. joet
    4,676
    915
    To flatten it, use a rubber glove and keep the glove moist, we use Windex.
    It will lay down on its own
  9. BikeNFish
    2,858
    1,764
    Apr 24, 2017
    Maplewood, MN
    No
  10. Kasey Redrum
    Kasey Redrum Member
    32
    Oct 17, 2019
    I want to update, I was not able to tool it at all with finger/windex. So don't try that, it is not like normal caulk.
    It is also not drying as hard as I thought it would. still slightly tacky and it has been 4 days. I am afraid to put the cover back on as I dont want it to stick.??
    And it has been in the 80s here, no rain.
