Repaired it myself!
Discussion in 'Miscellaneous Repairs & Maintenance' started by abc123, Sep 5, 2015.
  1. abc123
    abc123 New Member
    77
    Sep 11, 2013
    We got a great deal on a 2007 fleetwood niagara for 4300.00! They were selling it because they had got side swiped and thought damage was major. After viewing I saw no structural damage, just cosmetic. It was one owner, garage kept and super clean. We purchased on the spot.
    I took it to 2 different repair shops to get quotes. Both were around 1500.00. However neither would tell me a time frame of when they could repair it. Frustrated by their non interest to repair, I decided to tackle it myself.
    So for just about $300 in total materials I repaired it myself. I must say I gave myself a pat on the back and pleased how it came out. Was even happier to sell our 2000
    Starcraft 2410 for 4000.00 to the first caller after posting on Craigslist for just 2 days!
    So with materials and difference in selling our pup, we got the Niagara for $600.00 : )
    Here are some pics of before and after
  2. abc123
    abc123 New Member
    77
    Sep 11, 2013
    More pics
  3. Snow
    11,164
    1,830
    Nice repair job.. By looking at the before pictures I don't think it got side swiped like the PO said. Looks more like it got banged up while being pushed into or pulled out of the garage it was stored in. Either way a great buy and great repair..
  4. abc123
    abc123 New Member
    77
    Sep 11, 2013
    A few more. The grey n black water valves got ripped off so I re plumbed it also.
    On our trial run this weekend. Everything good so far. Love the hard wall shower/toilet. NOT a fan of the 3 way fridge. I will probably change it out to electric only. It is to slow to get cold. We will rarely boondock. If we did, I would take a quiet Honda generator!
  5. Jimmy the rug
    Jimmy the rug New Member
    60
    Aug 5, 2014
    Wow great job congratulations job well done
  6. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Thanks Snow.
    You never know. The paint/pin stripes did have swirl marks like a tire got it. The weird thing was they said they never felt it! Just behind the wheel trim you can see paint and stripes still messed up. I will touch it up or maybe cover with diamond plate.
  7. swordfish
    swordfish Well-Known Member
    2,220
    46
    Sep 27, 2010
    Pat yourself on the back with ease.
  8. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Thanks Jimmy and LOL swordfish!
  9. Hoosier Daddy
    Hoosier Daddy Active Member
    1,331
    Jun 24, 2014
    Fantastic job...nice save!
  10. ericgregoire
    ericgregoire Member
    140
    Jul 10, 2012
    Ottawa - Canada
    Nice, Nice.
  11. Wrenchgear
    3,535
    788
    Aug 5, 2010
    5 Star Eagle Camper
    Thats a no-brainer on that one. Good price, easy enough fix. Great job on your part.
    Keep the 3 way fridge in there and do the fridge fan mod that is all over the Portal. That fridge will cool down fast and get so cold you'll freeze your pops.
  12. mschepac
    mschepac South Jersey
    1,386
    Apr 22, 2008
    South Jersey
    I think I would have run the diamond plate around the whole unit. I like it! Good Job!
  13. generok
    3,004
    1,453
    Feb 7, 2013
    Anchorage, AK
    Kudos, sir, for your gumption and acumen. In this "it's cheaper to repack it" world, it is nice to see someone fix something, and do a nice job of it. It looks great, and you can put your hands on your hips and admire it with pride.
    Generok.
  14. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Thanks for the comments everyone. We took it out over Labor Day weekend for our trial run and everything worked great. Shower, toilet, micro, ac, radio, sink, hot water heater, fridge/freezer, black n grey tanks....all was good with no problems.
    Yes mschepac I like the diamond plate also. However that section was $75. Would cost $$ to go around. I original wanted to cut the back of the popup all the way across, use that section to repair side so the pin stripe would match, and put diamond plate across the back as it would match the diamond plate on the front.
    I decided nobody can see both sides at once.
  15. Igoo65
    Igoo65 Member
    46
    Jun 12, 2014
    Abc123, I just wanted to say great job! I have a 2005 Niagara and it has some damage to the drivers side front corner. The vertical trim piece on the corner that covers the screws was bent in the collision. How did you straighten your trim piece, or did you have to replace it. If you did have to replace it, where did you get one? How did you attach the diamond plate and what thickness did you use?
    Igoo65
  16. jmkay1
    6,169
    3,015
    Kudos to you. That damage did look scary. Then again I'm not very good at repairs, but getting better when I realize I'm saving over thousand dollars.
  17. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Hi Igoo65,
    The vertical trim piece I straightened out myself and then touched up with some paint. I just beat it with a rubber hammer and used a pair of pliers and screwdriver to straighten. I did buy new rubber insert to cover the screws.
    To straighten it I did completely remove it from trailer. When I put it back on I put new putty so it sealed well. It is the putty that comes in a roll and has a paper wrap. Not sure of technical name.
    My local rv dealer had the rubber insert. It was .25 per ft. They probably have the trim but I did not ask. I did buy the trim that connects the diamond plate and original side panel together.
    If you cannot find any locally let me know and I can ask if they have it or at least what the trim is called. The store is just down the street from my business so I stop in frequently. If you need I can buy for you and ship.
    Thank you jmkay1. It was nice to save the money. I am sure the repair places will give me a call when their work slows down. Then my minor repair will be important because they are slow and need jobs!
  18. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Igoo65
    The diamond plate is 1/16 thick. I had a 15" tall by 4' piece cut and a 1" lip bent at the bottom. After I cut away the damage from the side panel I had screwed the diamond plate from underneath the trailer with self tapping screws. I then drew the angle I needed to bend it with a sharpe marker. I cut and bent it using the angle iron on my utility trailer as a straight edge.
    I then screwed it on permanently with the self tapping screws from under trailer.
    After that I put the flat trim to connect the diamond plate and original side panel together. I made sure they overlapped each other about 6". Again putting the putty behind the trim to seal and then screwing...well I actually pop riveted that trim to really suck the two panels together very tight. Pop rivets very easy to use and can buy gun at Harbor Freight.
    Once all done, the last thing was the vertical trim and that was it.
    The piece of diamond plate cost me $75.
  19. abc123
    abc123 New Member
    77
    Sep 11, 2013
    Here is a close up of the trim. You can see it still has some scars from damage but I painted over it. I did cut a line with my hacksaw right where it makes the bend. I had to reshape it and it was not bending where I wanted it to.
  20. ricko
    ricko Member
    444
    Apr 6, 2009
    Nashville, TN
    Great work - Thank you for sharing with pics.
    This will come in handy if we ever have to do it to ours.
    Ricko
