Repairing front and rear ABS plastic
Discussion in 'Roof/Floor Repair & Maintenance' started by SebastianGator, Jun 7, 2021.
  1. SebastianGator
    SebastianGator New Member
    Dec 25, 2017
    Treasure Coast, Florida
    Where can one find real ABS pellets or sheets? I've searched the forums for the MEK formula and most say to use the airsoft BBS but the ones that I purchased apparently aren't ABS. I placed the BBS in a glass jar with a 1/2 covering of MEK for over 24 hours a wee bit cloudy but not dissolving like everyone elses says theirs are. Please, I need a vendor for either pellets or sheets to make the repairs that they have used. Thanks in advance.
  2. Raycfe
    17,422
    2,984
    Pellets are for sale on eBay and Amazon. Use a mix of 50/50. Let it sit a day or two.
    I would suggest that repair the backside of the panels and make it strong. I would use fiberglass and fiberglass mat. Then all you need is automobile filler to finish the outside
  3. SebastianGator
    Dec 25, 2017
    I need the NAME of the vendor or store not just you can find them on Ebay/Amazon. But thank you.
  4. Sjm9911
    9,316
    6,714
    Are you using the mek or acetone? Acetone takes a bit longer. The pellets i got are out of stock on amazon, but some came up with a abs pellet search. You xan use legos also, but thats probably more $$$. I think there the same as for the 3d printers.
    Raycfe likes this.
  5. Raycfe
    17,422
    2,984
    SebastianGator likes this.
  6. Negativez0
    Negativez0 Member
    33
    19
    Jul 26, 2020
  7. SebastianGator
    Dec 25, 2017
    I have 2 1 quart sized Mason jars that I've been using. One with MEK and the other with acetone. I've done a flame test as well as chemical test on what I was told by 4 different sellers both on eBay and Amazon that the product was ABS. None of them tested properly. I'm beginning to think that ABS is a "white elephant" for me.... Think I'm just going to do either sheet metal or diamond plate and just bight the bullet.
  8. Verde
    Verde New Member
    Apr 26, 2021
    DFW, Texas
  9. SebastianGator
    Dec 25, 2017
  10. SebastianGator
    Dec 25, 2017
    I'll check them out.
    Verde likes this.
