repairing rot on my door.
Discussion in 'Miscellaneous Repairs & Maintenance' started by klhayes77, Aug 11, 2008.
  1. klhayes77
    klhayes77 New Member
    33
    Jul 12, 2008
    I have a 1996 Jayco 1207. My entry door has some rot on the inside.I am going to try to repair it myself and I was wondering if anyone else has done this repair,and how hard it is to do. I am not missing any parts to the door.The problem is the paneling on the inside has rot at the bottom.If anyone has any advice i would appreciate it. Oh by the way the dealer said a new door would be around three hundred dollars. Thanks in advance for your advice.
  2. jwrigley
    jwrigley Member
    57
    May 21, 2008
    alton, Il
    Did you get your door repaired? I found the same thing on my door tonight.
    Jeremy
    98 Jayco Eagle <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp">
    04 GMC 1500 <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle">
  3. kmh1596
    kmh1596 Wilbraham, MA
    5,362
    Aug 20, 2007
    Western MA
    Once you get it repaired, be sure to seal off where the water was coming in! Do you have any photos of the repair? I hope the repair goes smoothly, and it didn't get further than the door!
    *Kevin*
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> 2004 Rockwood 1940 LTD, <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> 96 Cherokee 2dr 5spd, <img src=../Images/icons/icon_smile_canoe.gif border=0 align=middle alt="Canoe"> ~16' Old Town Canoe
    Nights Booked 08: 48, Camped so far: 39
  4. binky
    binky New Member
    484
    Aug 22, 2007
    Virginia
    My Coleman has the same problem.....I took it off and carried it to a local cabinet maker. He is going to rebuild the framing and backing(with plywood...not fiberboard) for $75. A new door is over $250.
    The aluminum skin and rails (top and side) will be re-used, but the innards are being replaced.
    Good luck with it.
    Me and DW circa 1969
    DS circa 1999
    DD circa 2003
    <img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> 97 Coleman Laredo
    <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> 96 Honda Passport 4 cyl.
  5. klhayes77
    33
    Jul 12, 2008
    No i have not done the repair yet.We had a small family medical emergency.My dad had to have his appendix removed and i work a family bussiness. So i can see a long week or two ahead for me.Hopefully i can get on it in a couple of weeks,
  6. jwrigley
    jwrigley Member
    57
    May 21, 2008
    alton, Il
    Well I ended up repairing the door tonight. The door pretty much fell apart once I took the screws out of the frame. I then took the door up to a friend of mine and he cut me a new door out of 3/4 plywood. I then used a little shoe goo to hold the door skin to the new wood and then re-installed the frame. I still have to pickup some new screws for the door frame but after that all I have to do is re caulk the door frame and attach it to the pup. My only concern is the weight of the new door. I am going to keep my eye on the hinge to make sure that everything is ok. If it turns out to be too much weight I will have to build a door very similar to factory.
    I will take a few pics tomorrow.
    Jeremy
  7. jwrigley
    jwrigley Member
    57
    May 21, 2008
    alton, Il
    Ok well i didnt get to take any pics durring the repair process because i thought it was going to rain so i only have a few pics.
    The added weight of the new solid door does not seem to be an issue as far as I can tell But I will be keeping an eye on it just to make sure.
    <img src="http://i43.photobucket.com/albums/e364/budnik74/100_3941.jpg" border=0>
    <img src="http://i43.photobucket.com/albums/e364/budnik74/100_3942.jpg" border=0>
    <img src="http://i43.photobucket.com/albums/e364/budnik74/100_3943.jpg" border=0>
    <img src="http://i43.photobucket.com/albums/e364/budnik74/100_3944.jpg" border=0>
    Jeremy
  8. klhayes77
    33
    Jul 12, 2008
    Well it looks really good. I think i might try and build mine the same way. Hopefully the weight wont be a big deal.I will try to take some pictures of mine while i am doing it.
